Go Back   maXbimmer Forums > Specific Regional Topics > Quebec/Gatineau/Ottawa
Old 05-07-2010, 10:20 AM   #721
carjoe
carjoe's Avatar
I've been looking into that but some mention it will need a tune to take advantage of the larger runners. Otherwise all the gains in the top end.
Phil, how long did it take you? Where did you get all the parts from? Dealer? I usually send an e-mail to Jared@EAC Tuning but he seems to be ignoring my last request....
93 325is - sold!
2000 540ia- sold!
Old 05-07-2010, 02:21 PM   #722
Philboski
Philboski's Avatar
I got my parts from Bimmerspecialist.ca, using the parts list on the site -- your might be different because of the TU. Lots cheaper than the dealer would be, I think.
The job itself took me a couple of days, but as noted, I screwed it up. As a result, some extra time was spent, then extra money. I went really slow, putting all of the parts in separate baggies labelled to correspond to the instructions. If I recall correctly, I started after lunch the first day, and "finished" the second day.
A big warning -- clean the area around the intake ports on the head. When you think you are done, do it all again. I had to buy some specialised attachments for my shop vac to get crap put of my intake ports. Highly annoying. And drain the coolant -- when you pull the water manifold off, it will spill all over the place if you don't. I speak from experience.
How do you know the valley pan's bad?
Philboski is offline   Reply With Quote
Old 05-07-2010, 02:26 PM   #723
Philboski
Philboski's Avatar
Now, back on topic. A steal for the mechanically inclined:
http://www.usedottawa.com/classified-ad/11951887
Old 05-07-2010, 05:05 PM   #724
carjoe
carjoe's Avatar
That one and the E34 M5 are beautiful...
How do I know? I dont' know for sure but I have an unexplainable coolant loss and a slight oil leak at the back of the block. Since I know the VCG on the passenger side is leaking, might as well do it all. Mechanic suspects the upper timing chain cover is leakign leaking too. Yay for 10 year old wundercars!
93 325is - sold!
2000 540ia- sold!
Old 05-07-2010, 05:08 PM   #725
chromius
chromius's Avatar
The valley pan is an easy visual check to see if it's leaking. I would make sure that's it before going through all the work of replacing it.
Old 05-07-2010, 05:15 PM   #726
carjoe
carjoe's Avatar
The way it's going, I think it's safer to do it all. The one that's really bugging me is the coolant leak. I get a message every other week. I top it off, bleed it...it comes back!
BTW, anyone have a mityvac? I have to bleed my brakes this weekend.
93 325is - sold!
2000 540ia- sold!
Old 05-07-2010, 05:25 PM   #727
zarbat007
Looks to be a nice DIY write-up.
Let me know if you need help.
When/where are you gonna tackle it?
zarbat007 is offline   Reply With Quote
Old 05-07-2010, 05:53 PM   #728
chromius
chromius's Avatar
The Valley pan isn't one of those catastrophic failure points, so personally I wouldn't do it unless it needs doing. I would track down where the leak is, then go from there. It's a lot of work for nothing, if it doesn't need doing. IMO anyway .
Old 05-10-2010, 08:56 AM   #729
Philboski
Philboski's Avatar
Agreed with Chromius -- I would verify it isn't a hose (like a heater hose in back of the engine) or a hairline crack in the expansion tank or rad before I went after the valley pan. A couple of hours looking things over might save you a bunch of time and money in the long run.
I have a coolant leak like yours in terms of how often I have to top up the coolant, and it's the expansion tank -- I just haven't gotten around to fixing it yet.
Old 05-13-2010, 10:27 PM   #730
Duct_Taper
Sticky
Duct_Taper's Avatar
http://ottawa.kijiji.ca/c-cars-vehic...AdIdZ204908571
Down to $1900... damn I wish I had some money right now.
Duct_Taper is offline   Reply With Quote
Old 05-14-2010, 08:24 AM   #731
Philboski
Philboski's Avatar
Those are rare with the six-speed too.....
Old 05-14-2010, 09:52 AM   #732
Duct_Taper
Sticky
Duct_Taper's Avatar
Yup. If it's in decent shape otherwise, anyone with the mechanical know-how could easily swap the clutch and flip that for double the current asking price.
Hence why I wish I had some money.
Old 05-14-2010, 12:11 PM   #733
jeffrie
Addict
jeffrie's Avatar
Clutch is easy to change, it's the "and other TLC" that would have me worried.
Old 05-14-2010, 03:03 PM   #734
Duct_Taper
Sticky
Duct_Taper's Avatar
http://www.usedottawa.com/classified-ad/12017002
http://www.flickr.com/photos/1074942...7603816406188/
Ridiculously clean-looking E21 for not much money.
Old 05-18-2010, 10:05 AM   #735
Philboski
Philboski's Avatar
Nice E36. The lack of a mileage listing is worrisome......
http://www.usedottawa.com/classified-ad/12033133
EDIT: The same car is on kijiji with a mileage listing of 200K
