Old 10-15-2008, 10:51 AM   #1
andicanada
andicanada's Avatar
E30 with s52 engine dropping compression
Hey guys !
i need to know what kinda power would a S52 put out with a obd1 conversion and dropping the compression down to 8.5:1 with fordged pistons
right now i spend already over 3000 grand on the engine and thought to put a hold on the Turbo for the winter only, starting next spring i wanne get things done as i also have not much time now but still would like to drive the car
any answers !?
Bye Andre
Old 10-16-2008, 12:36 AM   #2
NOTORIOUS VR
NOTORIOUS VR's Avatar
Originally Posted by andicanada View Post
Hey guys !
any answers !?
Bye Andre
Honestly, does it matter? I mean I know you are curious. But no one will be able to tell you for sure. So why not worry about getting the car ready and driving and take it to the dyno and you'll see exactly how much it'll make
Old 10-16-2008, 01:31 AM   #3
andicanada
andicanada's Avatar
i know i know i placed the order today for VAC motorsport stuff lol a total of 3 grand
now i have to look whats left in my pocked right now lol
i was thinking get a paint job at first and now my car looks the same but i have a engine for like 4.5 grand but not even a turbo on there lol
Old 10-17-2008, 12:14 AM   #4
NOTORIOUS VR
yes well doing things right takes time and money (as you've clearly figured out).
Enjoy your project and do things properly. It'll only make it so much more enjoyable afterwards believe me.
Don't worry about the power output of the motor while it's still N/A. That's not what you built it for. Enjoy it for what it is, and once you do finish your turbo kit you'll wonder why you ever cared about what you were making before
Old 10-17-2008, 12:18 AM   #5
PedroBMW
Hooked on Boost
PedroBMW's Avatar
are you trying to figure out how much power you'vr lost due to your compression drop? or how much power you can potentially get when you boost it? sorry im slow
http://www.foldingtrailers.ca
Old 10-17-2008, 12:28 AM   #6
Better question is how much of that Hp you can use in the winter, and just how well your winters can hook up! ROFL...
Old 10-17-2008, 11:11 AM   #7
andicanada
andicanada's Avatar
i dont need to use any hp in the winter from that car as i have 2 cars lol
so!
and yes i would like to know how much hp that engine would put out on 8.5:1 compresion with no turbo.
and second with turbo lol
Old 10-18-2008, 02:49 PM   #8
FuryriderX
cra.iX.y
FuryriderX's Avatar
no turbo: lots
turbo : lots more!!
Old 10-18-2008, 05:26 PM   #9
e30_kid89
The Afro-stig
e30_kid89's Avatar
AFAIK dropping the compression without turbo will see losses in power versus stock numbers since the s52 is generally a high compression motor.
Old 10-18-2008, 07:18 PM   #10
andicanada
andicanada's Avatar
i know that !
but as i see none real could name a # !
so i think i will go and put that sucker on the dyno and look lol
i will let you guys now then
Bye Andre
Old 10-19-2008, 12:35 PM   #11
PedroBMW
Hooked on Boost
PedroBMW's Avatar
i dont know of anyone whos dyno'd a NA low compression motor. Could you post up your results here???? it'd be intersting to see.
Old 02-19-2009, 11:24 PM   #12
velocity
supercharged
velocity's Avatar
why would you want to waist your money on a dyno run just to find out what your low compresion engine is producing?? just save your $ and turbo it, with that compresion you have to run at least 14psi and if my numbers serve me correct you are good for an easy 30psi also remember is power to weight, your e30 is about 500 lbs lighter then an e36.
velocity is offline   Reply With Quote
Old 02-24-2009, 12:08 AM   #13
theox69
theox69's Avatar
get an e36 m3 supercharger from active autowerke or something...forget the turbo.
theox69 is offline   Reply With Quote
