Old 10-09-2008, 06:15 PM   #1
Wingking
Wingking's Avatar
1985 E30 STROKER project, COMPLETED aaaaaaaaaaand...
.....IT WON'T START!
awesome times.
85' ETA engine was tossed. ETA bottom end "I" head- reconditionned.
All of the ETA 2.7 DME/Wirring harness was tossed, and replaced with full wirring/dme (173) from 2.5L
checked;
-Coil
-crank position sensor
-fuel pressure
-DME (tested on other car)
Healthy turnover, just no spark.
any other thoughts?
Wingking is offline   Reply With Quote
Old 10-09-2008, 07:32 PM   #2
325isdan
main relay?
325isdan is offline   Reply With Quote
Old 10-09-2008, 08:16 PM   #3
SamE30e
SamE30e's Avatar
Is there spark and fuel?
Check the coolent sensors, and make sure the timing reference sensor and engine speed sensor aren't mixed up if you're using the eta tranny.
85 325 - Turbo M52B28.
Old 10-09-2008, 09:11 PM   #4
Wingking
Wingking's Avatar
theres fuel, just no spark
main relay checked out
would coolant temp. sensor cause no spark?
I'll check engine speed/timing ref sensors next...thhx!
Old 10-09-2008, 10:07 PM   #5
El Gato Liso
El Gato Liso's Avatar
fuse 11
R.I.P. E30
Old 10-10-2008, 12:15 PM   #6
Aveman
Aveman's Avatar
You'd still get spark if your coolant temp sensor was bad, just once its started and warmed up the tune will be off.
The timing reference sensors on the tranny are useless now, just cause you're saying you going to check them I have to ask, did you bring over the trigger wheel from the 2.5 and the front crank sensor with mount? If you don't have spark any everything else is good, it's probably going to be crank sensor related.
Aveman is offline   Reply With Quote
Old 10-10-2008, 12:44 PM   #7
NickP
NickP's Avatar
Getting spark? Is the green wire on c103 hooked up to anything?
*edit*
Actually I should take a step back and ask what year the wiring harness is from and how you have it connected. I assume your 1985 eta has a square plug c101
Old 10-10-2008, 08:05 PM   #8
NOTORIOUS VR
NOTORIOUS VR's Avatar
are you getting 12V+ to the coil?
