Old 10-05-2008, 12:13 PM   #1
Nguyen_E30
Heo Quay
cloth seats to heated leather seats
i recently replaced my old interior with some leather. my car has no heated seats. so i got a link up on some heated leather seats. the seats came out of a 1990 325i i believe. i know the seats connect to a wire under the seats.
what i was wondering was. how do i connect these heated seats into a car that came without heated seats. will i need to part some other parts from the original car the seats came out of?
any input is much appreciated.
Nguyen_E30 is offline   Reply With Quote
Old 10-05-2008, 02:25 PM   #2
andicanada
andicanada's Avatar
you need the wiring harnes in order to do that you still can buy the harnes new from BMW or go and get a used one!
go on realoem.com and look there what you need and i hope it helps you out a bit as you also see the location of the harnes you are looking for
Bye Andre
Old 10-05-2008, 10:24 PM   #3
supernaught
supernaught's Avatar
i have a sale pending on wiring harness, switches and centre console. buyer is in the same position as you.
When I removed the harness from the parts car, there were only 2 or 3 wires that went to the car wiring, and I cut them just under the drivers door sill with enough length to be workable later. I believe they are fused, but im too lazy to get out my manual right now. Then you would have to fuse it yourself.
good luck, if the sale falls through, ill let you know if you're interested.
Old 10-05-2008, 11:15 PM   #4
andicanada
andicanada's Avatar
the harnes is 1 pcs and goes under the dashboard there is a conector where also the powerwindows are plugt in
when i remeber right the seatheater goess right beside the windowlifter plug
that means the harnes is plug and play
http://www.wp1016621.wp027.webpack.h...030/f00030.htm
i hope that will help you also
