Old 10-02-2008, 05:34 PM   #1
slimjim
Almost Sideways
ignition problem? motor is bogging!
ok, so when ever it rains and i start my car, the idle becomes extremely rough and even if i press the gas, it doesnt even try reving higher. i have to hold the gas down and every few seconds the motor will rev, then bog again. i have to wait about 5 minutes until the probblem goes away. This only happens after or during rain fall.
My distributer cap and spark plugs are new. im thinking it has something to do with the spark plug wires? what do you guys think. O ya, the motor is an m20
Old 10-02-2008, 05:37 PM   #2
FuryriderX
cra.iX.y
FuryriderX's Avatar
spray the wires with wd-40 next time this happens, then try again. if your problem is gone then you found the issue. (water getting into them)
bavauto is i think the place to go for wires. they're pricey elsewhere
Old 10-02-2008, 07:26 PM   #3
e30jones
Is the coil a possibility? I have the same problem, and I have new wires, plugs, cap, rotor. If you figure it out, post up.
e30jones is offline   Reply With Quote
Old 10-02-2008, 07:27 PM   #4
slimjim
Almost Sideways
ya, i just checked the wires, and im almost positive its not them.
Old 10-02-2008, 07:32 PM   #5
Max_VQ
Max_VQ's Avatar
Try this: At night open the hood, start the engine and use a spray bottle and spray the ignition wires and coil.
If something is worn out/bad, you will see sparking where the problem is.
Old 10-02-2008, 10:19 PM   #6
slimjim
Almost Sideways
ya, i was thinking about doing that, well thats wat my dad said. ill do it now and come back with the update!
Old 10-02-2008, 10:29 PM   #7
slimjim
Almost Sideways
!!! found it, its wlong the wire that goes to the coil, its touching the shock mount, is there any temp fixes for this?
Old 10-02-2008, 10:55 PM   #8
e30_kid89
The Afro-stig
e30_kid89's Avatar
electrical tapee that hoe!
Old 10-02-2008, 10:59 PM   #9
Yep, electrical tape the shit out of it and use a tie wrap to help keep it away from the shock tower.
Old 10-03-2008, 12:40 AM   #10
slimjim
Almost Sideways
what u guys want to ttrade ur e30's for mine?!
thanks for the help!
Old 10-09-2008, 11:36 AM   #11
WillieE30
If you have a hole in your coil wire from the ignition arc you can plug it by using RTV silicone(silicone caulking or hi temp silicone that crappy tire sells). The dielectric properties is quite high and will stop the issue. But I think you know, that it is time to replace your wires. This will help temporarily.....good luck........Bill
WillieE30 is offline   Reply With Quote
