Old 09-30-2008, 07:21 PM   #1
iBUYuRENT
My Emergency Brake Light Comes On While Im Driving??
Anyone Know What That Means? Or What Causes The Light To Come On?
Thank You.
WWW.FACTORYTIRE.NET
COOLEST WHEELS! HOTTEST PRICES!
1402 MARTINGROVE RD.
REXDALE, ONT.
416 744 1414
iBUYuRENT is offline   Reply With Quote
Old 09-30-2008, 11:37 PM   #2
Cliff21
Check your brake fluid level. You may also want to check the pads to see how much life is remaining.
Cliff21 is offline   Reply With Quote
Old 10-01-2008, 12:43 AM   #3
arsevader
Thank You.
The switch for the light is usually under the brake handle boot. Take a look it may be loose or shorted.
Brake fluid has no bearing on the emergency brake.
'85 325e
'90 325i
'02 325it
'03 320i
'96 Volvo 850R
arsevader is offline   Reply With Quote
Old 10-01-2008, 10:58 AM   #4
hackman
Thank You.
I have seen that problem on a buddys car it was the switch under the brake handle. but like stated above check the others also. As I have seen some people replace the switch and it made no difference.
hackman is offline   Reply With Quote
Old 10-01-2008, 01:49 PM   #5
ImolaZHP
ImolaZHP's Avatar
+1 just lift up the handbrake boot from the back(requires a little force) and you'll see a switch with some wires coming out of it
Old 10-02-2008, 12:33 AM   #6
Cliff21
True, but in most cars the e-brake light will come on if there is a fluid issue. I can't recall if the e46 has a separate indicator for low brake fluid - if it does disregard my previous comment.
Checking the fluid level is a fast and no-cost check anyone can do - and should do from time to time.
Old 10-02-2008, 08:29 AM   #7
arsevader
Some cars in the past used the main brakes as the emergency brake. This isn't the case with BMW, they all have separate parking brakes.
The fluid check advice is good though.
'85 325e
'90 325i
'02 325it
'03 320i
'96 Volvo 850R
Old 10-02-2008, 10:30 AM   #8
That doesn't have anything to do with which warning light would come on.
It's very likely it could be low fluid level, if the switch itself hasn't malfunctioned.
If your car has an OBC it will also tell you CHECK BRAKE FLUID, but not all models have it.
Old 10-03-2008, 05:54 PM   #9
arsevader
The OP parking brake light is on, why would that have anything to do with brake fluid?
NM I think I know what you mean.
'85 325e
'90 325i
'02 325it
'03 320i
'96 Volvo 850R
