Old 09-28-2008, 03:35 PM   #1
seanthomps
seanthomps's Avatar
vacuum leak on 92 325is, i need help!!
vacuum leak is driving me nuts!! need help plz
Hey guys, need some help here as im at the end of my wits, i have a '92 325is, with a serious vacuum leak as far as i can tell, causing the idle to move anywere from 600rpm to about 1400rpm. whats i cant figure out is the leak is intermittent sometimes idles alright, with only slight variation (between 100 rpm) soemtimes terrible (changing by 500- 1000rpm) all the hoses appear to be okay and its as if i can here it sucking in major air somewhere underneath the intake manifold, or throttle body plate, i was thinking possibly idle control valve, but i dont have enough experience or the money to just start swapping out parts, has anyone experienced a problem like this? your advice would be much appreciated!
thanks guys,
Sean Thompson
seanthomps is offline   Reply With Quote
Old 09-30-2008, 03:04 AM   #2
FLIPbmw
Ive been there, had it checked but did not find the cause.
How does your car run on the highway and acceleration? Is it still mean or do you feel it slop out and stutter? (JW b/c my car sometimes slops out, while other times it feels like its at peak performance).
FLIPbmw is offline   Reply With Quote
Old 09-30-2008, 11:18 PM   #3
seanthomps
seanthomps's Avatar
no pretty well has power all the time
Old 10-01-2008, 10:01 AM   #4
someguy
Singhy
i had a similar problem and found that my PCV valve had cracked and was causing a leak. It's only like 5 bux from the dealer, although I had to get one ordered because they didnt have it in stock. Check that out before moving on to more expensive stuff.
someguy is offline   Reply With Quote
Old 10-01-2008, 04:39 PM   #5
Lower_Level
No-Budget Enthusiast
Lower_Level's Avatar
where is the PCV valve in these cars? Might need to be something I should be checking...
'95 325is - //M Body - Shark Injected - Sport Pkg - Depo's with HID's
Lower_Level is offline   Reply With Quote
Old 10-01-2008, 06:09 PM   #6
AZE30
oxygen sensor can cause idle to fluxuate a bit.
AZE30 is offline   Reply With Quote
Old 10-08-2008, 07:12 PM   #7
seanthomps
seanthomps's Avatar
thanks for everyones input on my problem, replaced the o2 sensor and shes running much better, im very surprised thats the cause but i havent had a problem with it in about a week so im hopin she keeps runing good, thanks again for all the help!
