Old 09-15-2008, 05:44 PM   #1
cdb
cdb's Avatar
out of the blue: 98 528i mechanical problems
Arite guys. So I drove home with ease Monday night and parked the car. Woke up this morning, started her up and drove here closer up to the garage to give her a wash. The car started and ran just fine for these few seconds of movement. After the wash, I go to start her up and park at the end of the driveway, with no such luck. The car started, then immediately the revs died down and the engine stopped. Tried a few more times with no success. I have a feeling it is a problem with fuel getting to the engine. The car turns over just fine and does start, but then immediately dies. Maybe a fuel pump?
Any suggestions from you guys?
Christian
cdb is offline   Reply With Quote
Old 09-15-2008, 08:29 PM   #2
VSanj
once you get the car started step on the gas get your RPM's up to around 2-3000 hold it there for 10 seconds.....car will stay started once you let go of gas.
Mine did the exact same thing after a through wash once, never did it again
http://img186.imageshack.us/img186/11/vsanjsigdw5.jpg
VSanj is offline   Reply With Quote
Old 09-16-2008, 10:14 AM   #3
cdb
cdb's Avatar
Tried that. No luck.
Old 09-16-2008, 11:25 AM   #4
MLue1
MLue1's Avatar
Christian
just throwing these out... the MAF/connections located at the front of the car or the DME/connections which is located under the right side cabin filter, its sealed but you never know...when you wash the car a lot of water runs down the windshield into this area.
Mark
'99 E39 540iT
