Old 09-04-2008, 08:00 PM   #1
BMW.325IS
BMW.325IS's Avatar
Please Help Me Now!!!!
I am in nova scotia and was cleaning the car, doors and trunk were open but for some reason the car was locked, my keys and wallet were in the trunk my uncle comes along and closes the trunk. The alarm must be on becuase the center console switch and the trunk release will not open any thing!!! is there and way to get get into the trunk from inside the car? or a way to shut off the alarm so i can use the manual release!!!! i have access to the inside of the car ... PLEASE HELP the closes BMW is close to 2 hours away.
BMW.325IS
1995 325is-written off
2000 323ci- current
BMW.325IS is offline   Reply With Quote
Old 09-04-2008, 08:47 PM   #2
ImolaZHP
ImolaZHP's Avatar
you have the exterior trunk lock turned to the right(horizontal position) which makes it in valet mode, meaning you have to unlock the trunk with the key.
do you have the pass through seats? open your arm rest, reach your hand through and pull the glow-in-the-dark handle in the trunk.
Old 09-04-2008, 11:33 PM   #3
2005BMW325xi
2005 BMW 325xi
2005BMW325xi's Avatar
ImolaZHP
this question is for you since you seem to know alot about BMW, on my dash a left indicator signal comes on, and when I went to signal to make a turn it flashed fast, but I want to know if its my bulb or if its a loose wiring because it does it once in awhile.
2005BMW325xi is offline   Reply With Quote
Old 09-05-2008, 12:04 AM   #4
BMW.325IS
BMW.325IS's Avatar
i got my mother to go to my place and get my spare key she fed ex'd it over night from Whitby to Nova Scotia for $27.27 will be here guaranteed before 5 p.m problem solved thanks
BMW.325IS
2000 323ci- current
Old 09-05-2008, 09:20 AM   #5
ImolaZHP
ImolaZHP's Avatar
Originally Posted by 2005BMW325xi View Post
ImolaZHP
which flashes fast, the bulb or the green left arrow on the dash?
also do you have a bulb-out warning on the dash(the red car illuminates and stays on during driving with a little red indicator in the shape light near the front of the car)
Old 09-05-2008, 10:09 AM   #6
2005BMW325xi
2005 BMW 325xi
the green arrow flashes fast on my dash....once in awhile. But then after driving it comes back to normal. Yes is that what it is? Bulb-out warning? I need to replace my bulb then? (the red car illuminates and stays on during driving with a little red indicator in the shape light near the front of the car) that is so correct man! What does it mean time for a new bulb then?
Old 09-05-2008, 10:42 AM   #7
ImolaZHP
ImolaZHP's Avatar
first take out turn signal and make sure the harness is plugged in all the way. if that checks out then its the bulb.
just replace the front turn signal bulb and everything should be fine.
heres the DIY..its for an m3, but its pretty much the same deal.
http://m3.madrussian.net/diy_front_turnsignal.shtml
Old 09-05-2008, 01:29 PM   #8
2005BMW325xi
2005 BMW 325xi
ImolaZHP
Thanks once again man.....
