08-26-2008, 04:07 PM
#1
Car: 08 Civic
Need Your Help Boys.
I'm thinking my waterpump is toast.
Rad is pissing a bit after I turn the car off.
I can here the Rad Fluid Bubbling
Engine shoots to red in under 5 minutes...
Rad is full.
No Rad Fluid in the oil...
08-26-2008, 04:16 PM
#2
Car: E46M3/318TDS Touring
thermostat?
08-26-2008, 04:19 PM
#3
SHATTA M3
Car: 96 M3
IF U NEED a rad u can have if thats what u need
08-26-2008, 05:03 PM
#4
Car: '00 540i
rad cap?
Might as well do it all since you've got the system open...
93 325is - sold!
2000 540ia- sold!
08-26-2008, 05:55 PM
#5
Addict
Car: 97 318 IS
Ususaly you will have no flow without a WP ie rad wouldn't even get hot as no "hot" coolant is pumped to it, when cold take off the rad cap and start it, see if theirs any coolant pissing out of the little hole up top were the threads are for the rad cap, no flow = air in system, stuck closed t-stat or waterpump.
Hopefully you will not see a whole lot of tiny bubbles bubuling up in the coolant bottle and building pressure...That is the sighn of a blown head gasket.
08-26-2008, 08:48 PM
#6
Car: 08 Civic
Jeff: So far I turned the car on, opened the bleeder screw for the air, and alot of steam was coming out and hardley any spitting liquid(if that helps) also I noticed that the pipe going back into the rad(lower hose) was cold as crap and I was at 3/4 temp and then turned the car off. After the car was off that's when I noticed the hose start to get hot.. So any more diagnostics for me? I'm off all week and would be nice to fix this asap..
08-26-2008, 08:56 PM
#7
Car: '96 328i
It sounds like a thermostat to me.
08-26-2008, 09:04 PM
#8
Car: 318T
while we are on the subject ... I replaced my rad and never put back the sensor that screws in the radiator housing and haven't noticed anything wrong ... It's obv a temp sensor but what does it tell the DME to do ? is it very important?
08-26-2008, 09:21 PM
#9
Car: 08 Civic
Oh man I hope you are right.. could do that tomorrow.. I hope it's as cheap as my tercel $15 lol
08-26-2008, 09:25 PM
#10
Addict
Car: 97 318 IS
Well that bleeder screw has always been useless for me, should follow it to the open bottle and look their.
IMO from what you have described; since you had a almost overheating engine (3/4's to red) and only one hose is hot = to me a T-stat (stuck closed), air in the system (would need alot to stop that much flow) or most likly the WP.
FYI I'm off tommorow @ 11:30am... Want me to pick up the dealer only T-stat for you from Elite BMW? I can easily stop by since I drive by it on my way home and deliver it for you.
Edit: FYI I do not know were you live anymore or seen your new house yet.
Bear that sensor is to turn on the aux electric/AC fan if you were to ever get stuck in traffic and it's +40C outside which would need the extra air flow.
08-26-2008, 10:13 PM
#11
Car: '00 540i
Jeffrie, I'll meet up with you to give the pump to Tony. I work at the Hospital on Smyth, Elite is around the corner...
93 325is - sold!
2000 540ia- sold!
08-26-2008, 10:42 PM
#12
Addict
Car: 97 318 IS
Sure butt... wait and see what Tony is doing first in case he's up in Ottawa and might want to do everything himself.
08-26-2008, 11:02 PM
#13
Car: e46 M3
I'm with Jeff, definitely sounds like the water pump. I've seen your exact symptoms on other cars with WP failures.
08-26-2008, 11:06 PM
#14
Car: 318T
this is what maybe has happend up in there
08-27-2008, 12:00 AM
#15
Car: 08 Civic
Oh crap yeah that's wicked.. Jeff Give me your cell I'll pop by CT in the AM to see if they have any. Wonder what the dealer Charges for those things...
Should have got those parts at NAPA in the US, $53 for the WP and $23 for the T-stat..
