Old 08-23-2008, 06:50 PM   #1
ThoroldE30
Help!!
So the other morning i went and started my car and surprise to me the dash lights did not work(temp gauge, speedo, gas gauge, and rmp gauge) what could this be??
any suggestions would be great
its a 91 318i
~91 318i~
ThoroldE30 is offline   Reply With Quote
Old 08-23-2008, 07:40 PM   #2
325isStephen
Drifter
check fuses
Steve
Old 08-23-2008, 08:57 PM   #3
ThoroldE30
done that no luck
~91 318i~
Old 08-23-2008, 09:11 PM   #4
slimjim
Almost Sideways
relay?
Old 08-23-2008, 09:40 PM   #5
ThoroldE30
hmm good suggestion i will try in the morning seeing as how it is getting dark i will get back then
thanks
~91 318i~
Old 08-24-2008, 01:29 AM   #6
325isStephen
Drifter
good luck bro, hopefully its nothing major, to check the relay swap another one in from a different accessory that you know is good.
Steve
Old 08-24-2008, 09:54 AM   #7
BmW1819
if nothing lights up and nothing working in the car u gotta start where the power comes from the battery
Old 08-24-2008, 09:58 AM   #8
ThoroldE30
everything else in the car is working like even the signal lights come on when i use them still
~91 318i~
Old 08-24-2008, 01:52 PM   #9
racer-x
Everything in your dash has couplers that plug together. It sounds like the plug for your dash "pod" or gauge cluster has come unplugged.
Have you had stereo work done in your car?
racer-x is offline   Reply With Quote
Old 08-24-2008, 06:07 PM   #10
ThoroldE30
no i havent had anything with the stereo done
~91 318i~
Old 08-24-2008, 11:12 PM   #11
its a 91 318i
You sure the speedo gauge doesn't work? I had a similar problem last summer with my car... check your fuses again and report back. Actually... specifically, check the fuse thats controlling whatever circuit that the reverse light is on. That would be my guess.
Old 08-25-2008, 07:55 PM   #12
ThoroldE30
the speedo gauge itself works just no lights i checked all fuses but still no luck
~91 318i~
Old 08-25-2008, 09:06 PM   #13
Kirk930
Kirk930's Avatar
Dimmer switch? Turn the headlight knob.
'00 Viper - Steel Grey (ROE smooth tubes, RandomTech hi-flow cats, muffler delete)
'07 Infiniti G35 - Daily grind mobile
'04 Subaru WRX wagon - SOLD
'97 540i - SOLD
'87 Porsche 930 (B&B exhaust, SC cams, Garrett hybrid turbo, adjustable boost control, Andial fuel enrichment - 400 h.p.) - SOLD
Kirk930 is offline   Reply With Quote
Old 08-25-2008, 09:15 PM   #14
ThoroldE30
lol yea that was the first thing i though of
i think i am just going to run it into thorold imports come saturday and see what they can get of it
~91 318i~
Old 08-28-2008, 09:32 PM   #15
racer-x
If it's just the lights, it will be the dimmer switch.
