Old 08-21-2008, 12:13 PM   #16
aa34s
try to unplug the fuel pump relay and plug it back
the fuel pump relay is always happen on my e30
if it start then you still can use for while, but i suggest you replace it
most ppl think that's the fuel pump problem , but you better check the relay first, it save alot of money
aa34s is offline   Reply With Quote
Old 08-21-2008, 03:17 PM   #17
punnzzells
punnzzells's Avatar
Send a message via MSN to punnzzells Send a message via Yahoo to punnzzells
here's what I would check...
check the plugs, make sure they aren't fouled
check the distributor and make sure there is spark
check in tank fuel pump ( under the seat )
check the outside fuel pump ( driver's side rear )
check the idle control valve
check the battery ( i'd replace it if there's a dead cell )
punnzzells is offline   Reply With Quote
Old 08-21-2008, 03:25 PM   #18
zackman17
1.checked plugs not fouled put them in 2000km ago the look fine
2. checked there is spark
3.checked the pump is working.
4outside fuel pump? i thought mine only had the one pump????
5. i have ti get a icv but it's not jammed it's working right now.
6.stupid question but about the battery i went to ct they have no fkn listing of a battry for my car and they said it's not covered under warranty if it's not the battery that is for that car ...fkn stupid where should i get a battery the battery in it right now i 3 years old and it's too big what is the propper battery?
Old 08-21-2008, 03:29 PM   #19
zackman17
yo mike these are the bbs rs style rims i was telling you about
http://www.maxbimmer.com/forums/showthread.php?t=109317
Old 08-25-2008, 11:07 AM   #20
AWD_Guy
AWD_Guy's Avatar
My 325 wasn't starting either, and I found the fuel lines were pooched. You could see it spitting out under the car while you were trying to start, makes sense, no fuel, no start. LOL
AWD_Guy is offline   Reply With Quote
Old 08-25-2008, 11:16 AM   #21
supernaught
supernaught's Avatar
leaky return line could allow the fuel to drain out of the feed line back into the tank, that might be why you have to crank it for a while before theres any ignition - pump has to send fuel all the way from the tank when there would normally be fuel already at the injectors.
I bought a Motomaster Eliminator battery from CT when my car had a slow drain. The drain caused it to freeze when I was away on trips in the winter. CT replaced it under the battery warranty 3 times as long as I had the receipt. They gave me no grief over the model of the car. Besides you can get a good battery for $100 at CT. Then find out where your drain is.
Old 10-30-2008, 12:38 AM   #22
kungfucious
similar sickness
i had similar sickness with my 325e. it sounds like its fuel related which was my prob. short answer... theres a secret fuseable link in the trunk thats susceptible to being blown/worn out.
i had intermittent problems starting. would have troubles on warm starts, sometimes erratic revs, one time just died a slow death while waiting at a red. before you check that though... make sure your O2 sensor is clean and the DME is working cause if either of those arent... theyll mess up your fuel delivery too.
|OO=[][]=OO|
kungfucious is offline   Reply With Quote
Old 10-30-2008, 12:42 AM   #23
zackman17
i thought i checked that link but does it have a fuse?
im confused basically it's the main wires running from the battery right? i didnt see any fuse. i havent checked my o2 i will do that this weekend. more info on the fuseable link
Old 10-30-2008, 08:05 AM   #24
SamE30e
SamE30e's Avatar
If it runs and starts when it's warm, it could one of the coolant temp sensors.
85 325 - Turbo M52B28.
Old 10-30-2008, 05:44 PM   #25
zackman17
where is the fuseable link i cannot find it
Old 11-14-2008, 12:05 AM   #26
scott-[2CZY4
Scott-[2CZY4U]
scott-[2CZY4's Avatar
Send a message via MSN to scott-[2CZY4
well thanx for stayin till 6am putting my engine in zack. im now havin the same prob wont start. it wasnt pumping fuel up to my fuel rail so i pulled the line put an external pump and force pumped the fuel it seems to work fine onli had it runnng for 2 min as now rad or clutch slave in it
scott-[2CZY4 is offline   Reply With Quote
