Go Back   maXbimmer Forums > maXimum Tech > 6/8 series
Old 08-14-2008, 09:19 AM   #1
gcunha
Cluster in Milles/KLm
I recently purchased a 645ci from US, and the cluster comes with milles on the Outside and Klm on smaller fonts inside. Does anyone knows if I can buy a Canadian cluster or sticker to replace that one.
Thanks in advance.
gcunha is offline   Reply With Quote
Old 08-14-2008, 12:28 PM   #2
Gamite
Gamite's Avatar
Yes, you can purchase a candian cluster, and have it re-programmed for your car.
www.gamite.net
Old 08-14-2008, 12:46 PM   #3
Quack
Wheelman
Quack's Avatar
because there's already KM on the cluster you might not have to replace it, my friend did a conversion on a S-Class earlier today & the cluster is like what you described, but replacing the cluster wasn't nessecery, only if you don't have the KM readings you will need to replace the cluster, I think you should check with BMW Canada before you go & spend $1200+ for a cluster.
Old 08-14-2008, 02:33 PM   #4
Gamite
Gamite's Avatar
You don't, by law, have to change it if there are KM's on the cluster. That's how it was for my M5.
www.gamite.net
Old 08-14-2008, 03:13 PM   #5
Boots R
Boots, not boost
Boots R's Avatar
Did you have to reprogram the ODO to show in KM? Or did the border not care?
Old 08-14-2008, 04:17 PM   #6
Blades
Your opinion is to long
Blades's Avatar
theres a bylaw that it must show km?
-=[ BL/\DES ]=-
Old 09-19-2008, 12:17 AM   #7
nX07
nX07's Avatar
Any insights in regards to the law and KM's on the cluster? My friend bought a US vehicle that didn't have any KPH listings, only MPH.
nX07 is offline   Reply With Quote
Old 09-19-2008, 12:40 AM   #8
Blades
Blades's Avatar
all cars after (I believe) 1995 has km showing within the middle of the speedometer while you have mph on the outside. Car should be 100% legal in the sense of the cluster but if he were to change it .. it would be expensive unless he found a similar car in a crash or bone yard .. he can easily swap it out. Takes 2 minutes.
-=[ BL/\DES ]=-
