Old 09-10-2008, 09:07 PM   #16
sonspot
did the vanos seals and thermostat on sat, i would say its not hard, just time consuming because you have to remove alot of bolts but thats a given, i would its easy to medium for me, the last time i worked on a car was two years ago and nothing to do with the engine.. just read the DIY over and over while wait for the parts..
thanks
2001 330I, sport/Premium/cold weather package, short shifter with M3 weighted knob, clear corners, 60 led angle eyes
sonspot is offline   Reply With Quote
Old 09-11-2008, 08:24 AM   #17
2005BMW325xi
2005 BMW 325xi
2005BMW325xi's Avatar
Max_VQ
How long did it take to get the VANOS seals from that site? I was thinking to order it and have RPM do it or if you can help me install it let me know thanks man..
More info here: http://www.beisansystems.com/
2005BMW325xi is offline   Reply With Quote
Old 09-12-2008, 07:36 AM   #18
S.A.330iM
S.A.330iM's Avatar
my 330i has 92,000 klm im also interested.
B-bella
M-machana
w-WILIO
S.A.330iM is offline   Reply With Quote
Old 09-16-2008, 03:50 AM   #19
sonspot
i had mine shipped to the stats and picked it after shipping was fast, you need other parts like valve cover gasket, check the site for all the parts, any m54 should get this done no matter the mileage. the higher the more to get it done.
Old 09-16-2008, 09:12 AM   #20
2005BMW325xi
2005 BMW 325xi
sonspot,
I want to do it for my E46, but on the site it only shows "Double Vanos Seals Repair Kit (6-cyl)" - Item # BS001, $60 but how do you order the "Vanos gasket"? Does that come with the kit too?
This what it says on the site:
Vanos piston seals repair kit (BS001) $60/each
vanos gasket (11-36-1-433-817) 6.73/each (how do you order this item?)
2 x vanos oil hose/pipe washer (32-41-1-093-596) $.25/each (and this one too?)
Old 09-29-2008, 08:10 AM   #21
2005BMW325xi
2005 BMW 325xi
bump
above question anyone?
Old 09-29-2008, 11:02 AM   #22
ruckuss
I got the Vanos gasket from Parkview as well as valve cover gasket.. I installed my Vanos pistons seals yesterday.. man.. what a difference.. I recommend getting it done.. Its almost like a different car, no more hesitation or rough idle.. even the knocking noise is gone.
Money well spent.
ruckuss is offline   Reply With Quote
Old 09-29-2008, 11:10 AM   #23
ImolaZHP
ImolaZHP's Avatar
i need to do the seals soon as well
ruckuss: did they have those gaskets in stock, or did you have to order it through them?
Old 09-29-2008, 11:19 AM   #24
Max_VQ
Max_VQ's Avatar
Originally Posted by 2005BMW325xi View Post
sonspot,
The vanos seals do not come with any gaskets. I got mine from bimmerspecialist.com
Old 09-29-2008, 11:30 AM   #25
ruckuss
No, they had them in stock. I bought the two washers, valve cover gasket and Vanos gasket, cost me about $55 from Parkview BMW.
Old 09-29-2008, 12:17 PM   #26
2005BMW325xi
2005 BMW 325xi
I am sort of confused can anyone tell me what you need to order for a E46? What do you need in order to do a Complete Vano Seal? Please give me a list....thanks...
Old 09-29-2008, 01:44 PM   #27
ruckuss
You need the double vanos seals repair kit from Beisan.
you will also need Vanos gasket and valve cover gasket and 2 vanos oil hose/pipe washer. I got all these from BMW dealership.
With the double vanos seals repair kit from Beisan you only get 6 O-rings and 4 teflons seals.
hope this helps..
Just got back from lunch.. man... I love driving my car agagin.
Old 10-06-2008, 11:51 PM   #28
bimmerlvr07
Motor Head
bimmerlvr07's Avatar
get aftermarket pulleys...11hp gain...look on corner73.ca
[i]12' BMW X1 xDrive28I
bimmerlvr07 is offline   Reply With Quote
