Old 08-08-2008, 09:22 AM   #1
BRAD 82
BRAD 82's Avatar
Send a message via MSN to BRAD 82
Cylinder head swap question
Hello all,
I have a quesiton.
is there a quick way to remove the cylinder head off a 2.5/2.7l?
Thanks,
Brad
BRAD 82 is offline   Reply With Quote
Old 08-08-2008, 09:32 AM   #2
The quickest, is just to disconnect the intake mani, and exhaust n let it sit there. You can slip off the timing belt, but you still have to dis-assemble the bottom part to change it (which you should do).
Shouldn't be too hard.
Old 08-08-2008, 10:46 AM   #3
BRAD 82
BRAD 82's Avatar
so basically i should follow the bentley manual?
by that i mean take it apart and remove the bolts in the specific pattern as it describes?
Old 08-08-2008, 10:49 AM   #4
Yea the head bolts are the only ones you need to be concerned about.
Old 08-08-2008, 10:50 AM   #5
BRAD 82
BRAD 82's Avatar
that and lining up at TDC! thats the part that freaks me out!
Old 08-08-2008, 01:47 PM   #6
mirek
mirek's Avatar
TDC is nothing to be freaked out about, just make sure the notches align and you're golden.
Old 08-08-2008, 02:18 PM   #7
BRAD 82
BRAD 82's Avatar
awesome. thanks
