Old 08-07-2008, 09:04 AM   #1
jamestown
Officially
e34 door swap issues, HEELLLPP!
Hi guys I changed the doors on my 525i but the wiring for the door lock seems to be different. The back ones aren't a problem it's just the two fronts.
before when I turned the key it was mechanically moving the solenoid I think. On the doors I put on it's controlled by a switch.
On the doors I took off the actuator is attached to the latch. On the doors I put on the actuator is different and is attached to the handle assembly.
I think I need to wire the key switch to the solenoid somehow to trick the central locking system into thinking I am pulling up the pin that unlocks the doors from the inside.
If that's the case I will need to disable the double locking feature. Is there a fuse I can remove that does this, or am I going about this all wrong. Any help appreciated.
jamestown is offline   Reply With Quote
Old 08-07-2008, 07:34 PM   #2
parm
Scarboro Mazda S&L
parm's Avatar
Hey Jamestown
I went through the same issues I can refer you to the teck who did mines, i don't think the doubble locking has to be bypassed, and you would have to lock you car from the trunk or by pushing the lock down from the inside.
Old 08-07-2008, 09:04 PM   #3
jamestown
Officially
I can already lock the car with the drivers door from the outside, I just can't unlock it from the outside.
I can do without the interior door locks if I have to, I just don't want to keep using the trunk lock to get into my car.
I'll call you later and see who this tech is, maybe I can ask him how to do it. I'd rather do it myself if he can tell me what to do.
Old 08-07-2008, 09:31 PM   #4
parm
Scarboro Mazda S&L
parm's Avatar
switch the wires so you can unlock the door and just lock the doors by pressing down the lock from the inside thats how mine is.
