Old 08-05-2008, 12:50 AM   #1
NOTORIOUS VR
NOTORIOUS VR's Avatar
FS: 400RWHP M20 drop in turbo setup complete
Selling for my friend a complete drop in swap for any E30 or even E34 for that matter. He's going a different route so instead of parting it out, he would like to try to sell it as a whole. The whole swap should take you less the a weekend.
The motor is tuned and currently daily driven @ 20psi on pump gas. Made 374RWHP @ 18psi on a very hot and humid day. This setup make over 400RWHP on a nice cool day running at 20-21psi on the street. This car will start in dead of cold, and a super hot day.
A TON of tuning has gone into the car and will even return a very impressive MPG if you can force yourself to keep it out of boost. Just recently a drive to Montreal (all highway) with a few runs in boost still got under 9L/100km. How many 400WHP cars do you know can do that?
The swap comes with everything you need to get this running in your car. The only thing you'll need to do is 'continue' the exhaust from the downpipe onwards, and drop in an in-tank fuel pump (a Walbro 255 will do just fine, that's what this setup runs on).
You can come see the car, and go for a ride in it as well if you are serious about buying the setup. You will not be disappointed.
The following is included:
-Stock M20 Block - approx 260k - all seals were replaced, this motor is dry as a bone!
-New stock headgasket at the time on install into the current chassis,
and 885 casting head with complete I/IS valvetrain, welded coolant channels, then sent to get checked and machined.
-Raceware headstuds
-Schedual 10 backpurge-welded twin scroll up-pipe w/ T4 flange and 38mm Turbosmart wastegate and screamer pipe. This thing will support the weight of a 42R w/o breaking a sweat. No need for a oil filter relocation as with the 666 Fab. up pipe!
-Garrett T70ish twin scroll turbo (ish meaning it's a custom made compressor wheel, the turbo will support 600WHP no problem, so lots of room to grow with some race gas and/or meth injection)
-630cc Siemens flow matched injectors
-Spearco core intercooler with mounting tabs
-all stainless charge piping with Turbosmart BOV
-VEMS V3.3 stand alone with tuned map and all accessories (LCD screen, wide band O2, custom harness)
-Wastespark coilpack (no more distributor)
-2x 5 speed transmissions (the one that's in the car, and the other as a spare)
Asking $5500, that's a steal for what you're getting here. The tune alone in this car is worth about $2k in dyno/street time. Not to mention all the other parts. We've taken the guess work out of everything, just drop it in, plug it in, turn the key and go.
PM or Email for further info: notorious . vr (at) gmail . com
Picture of the setup in the said car (green intake mani is free of charge ):
Old 08-05-2008, 12:55 AM   #2
NOTORIOUS VR
Old 08-05-2008, 12:17 PM   #3
FuryriderX
cra.iX.y
FuryriderX's Avatar
that is just awesome. someone jump all over that.
on a side note, YGPM.
Old 08-11-2008, 09:27 AM   #4
NOTORIOUS VR
BUMP! Just went on the dyno yesterday did a little clean up tune... came out with 400.4RWHP @ 21psi.
You know you want it!!
Old 08-11-2008, 11:03 AM   #5
Holly ****! Sick ass.
Old 08-11-2008, 11:10 AM   #6
shimajer
loudddddd
hoyl smokesss
Old 08-12-2008, 10:27 PM   #7
NOTORIOUS VR
make an offer guys.... 400RWHP at the itch of your little toe! You'll love it I promise
Old 08-13-2008, 04:52 PM   #8
BMW BMXer
Wants a 350 Blazer.
BMW BMXer's Avatar
Your car is on throwing stars in the front right?
Stanceiseverything.com
Old 08-16-2008, 08:53 PM   #9
NOTORIOUS VR
Not my car but yes it's got the throwing starts up front with 14's in the back with some Azenis on them.
Old 08-17-2008, 05:10 PM   #10
d.maczko
Registered User
how long has this setup been running for at 18-21psi?
d.maczko is offline   Reply With Quote
Old 08-17-2008, 05:15 PM   #11
NOTORIOUS VR
a few months and many KM... and it's been daily driven at that psi ever since it was tuned for it as there is only a single stage boost controller connected.
Although that will change very soon... we're going to put a stronger WG spring in for base pressure and change the coil packs to new DFU's from Electromotive (GM coils). That should let us go further up in boost w/ some race fuel or maybe even W/I.
So first stage boost will probably be anywhere from 12-15 psi and 2nd stage 21 psi (or more with W/I )
