Old 07-14-2008, 06:22 PM   #1
BRAD 82
BRAD 82's Avatar
Send a message via MSN to BRAD 82
325e sounds like a diesel
Hello,
I am looking for some advice/help for my car.
when the car starts and runs (not really) it sounds like a diesel engine. Not to mention there is absolutely NO power to move the car with.
I believe that this is due to water in the gas.
any help/tips would be greatly appreciated.
Thanks,
Brad
BRAD 82 is offline   Reply With Quote
Old 07-14-2008, 09:14 PM   #2
slimjim
Almost Sideways
i dont know but this may be due to shitty injectors......because when injectors are old the can make that "tic tic tic tic tic" noise
slimjim is offline   Reply With Quote
Old 07-14-2008, 10:25 PM   #3
BRAD 82
BRAD 82's Avatar
and i guess water going through them probably finished them off?
Thanks slimjim!
Anyone else have any ideas
Old 07-14-2008, 10:34 PM   #4
mirek
mirek's Avatar
Run a compression test
Old 07-14-2008, 10:47 PM   #5
BRAD 82
BRAD 82's Avatar
how do i do that?
Old 07-14-2008, 11:16 PM   #6
slimjim
Almost Sideways
if u are getting water in ur engine, when the car starts or struggles to, white smoke would come out of ur exhaust. u might even have cracked rings? its hard to say.
is there anything else u notice when u start or try starting the car, did anything prior to this problem happen like overheating?
Old 07-14-2008, 11:23 PM   #7
BRAD 82
BRAD 82's Avatar
no it isn't water IN the engine constantly. it game from gas purchased.
it was water in the gas that caused the issue. tank has been drained now.
Old 07-15-2008, 12:02 AM   #8
mirek
mirek's Avatar
get a compression tester, and google for instructions, or take it to charlie, shouldn't take longer than half an hr.
Old 07-15-2008, 02:25 AM   #9
InfiniteDice
14 Years with the E30
InfiniteDice's Avatar
if it sounds like a loud lawnmower, or helicopter then its the bottom end bearings.
Had that sound on my old engine, tore it apart before putting in my new engine, all the crank bearings were scored.
Every engine gets some white smoke, and water for the first 5 to 10 mins. beyond that, does your coolant level get low? could be leaking coolant internally.
Later man.
Old 07-15-2008, 07:36 AM   #10
SamE30e
SamE30e's Avatar
My car does it too. It seems to be a normal ETA thing these days. It's the timing reference sensor, or the engine speed sensor one of the two on the bellhousing of the tranny.
85 325 - Turbo M52B28.
Old 07-15-2008, 07:39 AM   #11
Yeah, I had a vehicle that had that problem once, it only started sounding like a diesel engine though when the damage was bad enough (due to the lack of lubrication because of the dilution of the oil) that i needed an engine rebuild (new block)
Old 07-15-2008, 08:11 AM   #12
BRAD 82
BRAD 82's Avatar
engine ran fine before the issue of watered down gasoline.
will be getting a compression tester today and doing one tomorrow.
I hope its not too major of a problem. but i guess the compression test will tell me that! I am thinking it is a head gasket
Old 07-15-2008, 07:59 PM   #13
slimjim
Almost Sideways
how do u know it was watered down gasoline?
Old 07-15-2008, 08:39 PM   #14
BRAD 82
BRAD 82's Avatar
Well I never personnally saw it but the guy I bought the car off of said that was what happened. He also said it was drained.
That's what I have to go on. I am planning on running a compression test tomorrow to see what I get. Personnally I think it may be the cylinder head gasget. But we will see.
Old 07-17-2008, 06:38 PM   #15
BRAD 82
BRAD 82's Avatar
Ok. Ran the compression test and got 120psi on cylinders 1,2,3,5 and got 100psi on cylinders 4 & 6.
All the spark plugs are worn and probably need changing but this still doesn't mean the engine would sound like a diesel. Would it?
HELP PLEASE!!!
