Go Back   maXbimmer Forums > Multimedia > Videos and Sound
Old 02-06-2003, 04:21 AM   #1
swisherchico
dumb question...but does this guy hit all five gears
I was checking out this video on aatuning.com and I couldn't tell if this 3.0L 325i went through all five gears. It is the stutter after his tires start peeling out.....did he shift, or was the sound from his tires finally catching. I think he shifted cause I've never done 115mph in fourth gear.
anyways the question is did he only use four gears, or all five?
swisherchico is offline   Reply With Quote
Old 02-06-2003, 02:52 PM   #2
330DTM
Cinematographer
330DTM's Avatar
IT went through all 5 gears believe it or not. I heard all of the sequences!
First gear finished 4 seconds into the video and shifted into 2nd. Then by the end of 5 seconds into the video he shifted into 3rd. Shifted into 4th gear 7 seconds into the video.
Then shifted into 5th 11 seconds into the video.
That's M3Turboca by the way!
If that's the run he talked to me about, those were on worn out Bridgestone Re730 tires if I can remember.
I met him in person and his car is such a darn sleeper. That car really pulls and I believe it's the Stage I of the AA kit.
Can't wait till spring
-=Slow In Fast Out=-
Old 02-06-2003, 05:56 PM   #3
SickFinga
SickFinga's Avatar
Yep that's his car, PURE sleeper!!!
325 converted to 95 m3. All m3 parts are on that car.
I saw that car go, pretty impressive and he wasn't even pushing it.
P.S. Yes he went through all five gears, you can easily count them
M3 redlines at about 118mph in 4th gear
Old 02-06-2003, 08:10 PM   #4
Sickbimmer
750HP turbo E46 M3
Sickbimmer's Avatar
WOW 12.7@115mph That's impressive
Is he from around here?
How much power/ boost does he run?
Sickbimmer is offline   Reply With Quote
Old 02-06-2003, 08:43 PM   #5
SickFinga
SickFinga's Avatar
He is from Markham
Old 02-07-2003, 11:39 AM   #6
330DTM
Cinematographer
330DTM's Avatar
He's running approx. 12psi the last time I met him.
I think it's just a LITTLE over 400HP, but even in 5th gear at 3300rpm, once he taps on the gas, you can actually feel the torque pushing your body back into the seats.
Old 02-11-2003, 08:49 PM   #7
Sickbimmer
750HP turbo E46 M3
Sickbimmer's Avatar
Man, maybe I should swap the supercharger for a turbo
I'm tring to hit the 12 second 1/4 mile myself. No chance though
Old 02-11-2003, 08:52 PM   #8
SickFinga
SickFinga's Avatar
superm3, look ar RMS supercharger
400+ at the wheels
Old 02-11-2003, 08:54 PM   #9
Sickbimmer
750HP turbo E46 M3
Sickbimmer's Avatar
I you guy's don't mind, could you tell me where he got his car done at
I'm thinking of raising the boost in my car to 8-10 psi(currently 6)
Thanx
Old 02-11-2003, 08:57 PM   #10
Sickbimmer
750HP turbo E46 M3
Sickbimmer's Avatar
I don't really want to scrap my current set up. I'm just hoping to improve on it. The reason the RMS system has more HP then mine is the aftercooler allows for higher boost.
Old 02-11-2003, 09:15 PM   #11
SickFinga
SickFinga's Avatar
Why don't you get an intercooler? jonsibal was selling his
His car was done at AA Tuning headquarters in Miami.
Old 02-11-2003, 10:19 PM   #12
330DTM
Cinematographer
330DTM's Avatar
Hmm, I haven't seen anyone using a front mounted intercooler on vortech blowers so far.
For sure they do on the AA Rotex blowers.
Why not get the aftercooler and water injection kit for your current setup. It'll definitely help your car run more consistant and lowers the chance of denotation.
You could also get a LTW flywheel which would help as well for acceleration.
Old 02-11-2003, 10:41 PM   #13
330DTM
Cinematographer
330DTM's Avatar
Keep in mind that 12seconds may be doable for you. It's not just the power, but you're setup.
Running too low profile of tires will affect your traction for starts as does the amount of PSI you're running in your tires. If memory servers me right, usually you want to run more psi up front and less in the rear.
There is another guy on another forum, who has a Z3 3.0L (same engine as 330i) with a RMS superchager w/aftercooler running about 9psi. He can do a 1/4mile in 11.71 seconds. He pretty much knows the proper dragging technique and is pretty experienced.
Old 02-12-2003, 09:11 PM   #14
Sickbimmer
750HP turbo E46 M3
Sickbimmer's Avatar
Thanx for all your help with the info. Water injection is kinda costly and complex, the aftercooler is more suitable for my set up but so far I can't seem to find one without paying $1500.
To top it all off my insuance company just called me to tell me that they were discontiueing my insurance because of the charger. They want some sort of dyno test so I can prove the charger isn't putting out alot of HP
Old 02-12-2003, 09:52 PM   #15
Jon@Bimmersport
Jon@Bimmersport's Avatar
superM3...vortech has an aftercooling system made for their blowers, check it out...$1500 is a good price if its CDN, is that with install? dont cheap out with stuff liek this man...this can determine your engine staying together, or the engine being blown under higher boost!
Authorized Ontario dealer for Active Autowerke|VF-Engineering|AFE|Bilstein Suspension|H&R Suspension|KW suspension|Brembo Brake Systems| Stoptech| - Call us for the best pricing
