Old 02-06-2003, 01:58 AM   #1
SickFinga
SickFinga's Avatar
Need help with Euro m3 rotors and EBC green pads.
1. Can anyone tell me part number for the LEFT front euro m3 rotor.
2. Who carries EBC GREEN pads for E36 m3?
Old 02-06-2003, 02:06 AM   #2
WASABI
OG
http://stl_don.home.att.net/euro_rotors.htm#Resources
EBC Pads, Elite Auto carries them, last time I asked, Also JRP in Mississauga, but $$$.
Old 02-06-2003, 02:10 AM   #3
SickFinga
SickFinga's Avatar
Wasabi, link doesn't work, and about what money are we talking?
Old 02-06-2003, 02:14 AM   #4
WASABI
OG
just clicked it. it worked for me. but here's the info anyway that I cut and paste.
There are a few sources in the U.S., I re-searched it a while back, I forgot/lost the links. Do a search for "Euro Rotors".
Part Number Description
34 11 2 282 301 Right Front
34 11 2 282 302 Left Front
34 21 2 282 303 Right Rear
34 21 2 282 304 Left Rear
Cost: List price from BMW is $235.00 for front and $220.00 rear. Price is for each rotor. Best price I found was $682.50 for the set
Where to buy: Any BMW dealer can order the parts. There are also a number of aftermarket vendors selling them. I ordered mine from South BMW. Their web site is a work in progress. If you want to order from them call 800.833.7278 and ask for Paul McLaughlin.
Old 02-06-2003, 02:23 AM   #5
SickFinga
SickFinga's Avatar
Those are E46 M3 Crossdrilled rotors.
I need E36 Rotors.
Any ideas for how much ebc green goes for
Old 02-06-2003, 02:29 AM   #6
WASABI
OG
Ah Shiats ! Ma Bad ... BTW Teutonic has them listed for $325 each.
The pads are around $100 for the fronts.
"BMW Motorsport Euro 3.2L M3 "Floating" Rotors
These two piece floating rotors are lighter and transfer less heat to the bearing/hub assembly than the U.S. model one piece rotors, making them ideal for high performance applications. The rotor is made with dowel pins cast into the center opening, then the aluminum center hat is cast on the pins. Bolt on replacement for all U.S. spec E36 M3's.
P/N 34112227737(L), P/N 34112227738 (R) "
Old 02-06-2003, 02:30 AM   #7
SickFinga
SickFinga's Avatar
OK i think I found it:
34 11 2 227 737
Euro LEFT M3 rotor.
Old 02-06-2003, 02:35 AM   #8
WASABI
OG
LOL. yep choooo got it mang !!! Pacific Mall also has the EBC pads, forgot which store though.
Old 02-06-2003, 02:37 AM   #9
Soldo
Soldo's Avatar
SICKFINGA, don't do it, although the COLOR PADS are supposed to be GOOD (GREEN & RED) they're apperently not good brakes, i have a friend in the RACING BUSINESS and he said the pads wear out far too quick and they don't even STOP as good as the CLAIM, the best pads to get would be PBR metal masters, they're cheap too, i picked up pads for ALL 4 ROTORS for something like UNDER 100 CDN, from www.BMPD.com, might be a BIT more for YOUR CAR!
Keven Soldo
Old 02-06-2003, 02:44 AM   #10
M50E30
www.bmwclub.ca
M50E30's Avatar
I just picked up some PBR Metalmaster Delux pads ($29), Brembo X-drilled rotors ($80/each...contact empowerd for better price), stainless steel braided brake lines (front & rear for $145), and front caliper rebuild kit for my 2002. Hope to get everything installed soon. Will let you know how those pads work out!
Dave
Old 02-06-2003, 03:04 AM   #11
Soldo
Soldo's Avatar
WOW, where did you get the BREMBRO's from for THAT CHEAP?!?!
please tell, i need some come spring time(brakes are ALREADY almost gone, but i'll wait till spring for the X-DRILLED!)
thanks in advance!!
Keven Soldo
Old 02-06-2003, 03:10 AM   #12
SickFinga
SickFinga's Avatar
I DON"T want any brake dust, and I still wanna stop if some mofo cuts me off.
Old 02-06-2003, 03:25 AM   #13
M50E30
www.bmwclub.ca
M50E30's Avatar
thanks in advance!!
PM empowerd...he can get them even cheaper! I wish I knew before I bought mine.
PBR's are supposed to be very good for brake dust and performance. Got them @ http://www.eliteauto.ca/home.html
Old 02-06-2003, 03:47 AM   #14
SickFinga
SickFinga's Avatar
SHIT I knew it would happen. Now WHAT BRAKES SHOULD I GET??
MUST BE DUSTLESS!!!
Old 02-06-2003, 05:50 AM   #15
Spartiatis
Spartiatis's Avatar
Send a message via ICQ to Spartiatis
I have the Green pads and they are awsome. My rims dont get dirty anymore and they stop awsome. They also make zero noise. I think you should go for them. I got mine at JRP.
///M means "MotorSport" for the E30 ///M3
but
for the E36 M3, M means "Marketing"
Spartiatis is offline   Reply With Quote
