how did you wire up the deck ... ? did you use a wiring harness ? or did you splice into each wire and solder it ?
If you attempted the second way you might have soldered the deck power-on to something else than the acc power-on wire .... you should recheck your wiring, even if you used a harness ...
You also mentioned that your battery died after installing the deck ... Did you unhook the battery when you installed the deck? ... you should make sure you didn't accidentally strip off any wire shielding on the wires when installing the deck causing a short or current draw on the battery ... also check your fuse box for the radio and see if everything is ok there ...
I can't remember what it's called ... but it is a device you hook up to your battery and if there is any current draw on the battery, it will light up ....
Best of luck ...
Christopher ...
