Old 07-25-2008, 02:41 AM   #1
RKMA86
Power Door Lock Problems!!!!
98 E36 SEDAN...all doors work fine except for the drivers door.
when i push the lock button, all doors lock/unlock except for the drivers
when i push the remote button, all doors lock/unlock except fo rthe drivers
when all doors are locked and i open the driver door from the inside of the car, all the doors unlock.
when i push/pull down the thing at the top, all doors lock/unlock.
When I put the key in, all doors lock and unlock
Anyone know WTF is going on?!?!?!?
RKMA86 is offline   Reply With Quote
Old 07-25-2008, 12:07 PM   #2
Allstar_e36
Allstar_e36's Avatar
I believe its your door solenoid dying, that happened to mine and about 3 weeks later it died. Had to replace the solenoid.
- Sunny
Allstar_e36 is offline   Reply With Quote
Old 07-25-2008, 12:11 PM   #3
Boots R
Boots, not boost
Boots R's Avatar
You broke it. Way to go.
Old 07-25-2008, 01:12 PM   #4
vadim321go
vadim321go's Avatar
costs 100$ for the actuator (its not called a solenoid)
Proud owner of a 95 325i
Old 07-25-2008, 03:55 PM   #5
Allstar_e36
my bad Actuator, lol talk to Phil at eurostyle he can get u a used one for way cheaper or bimmersport can get you a new one.
Old 07-25-2008, 09:44 PM   #6
RKMA86
BOOYA...it started working again today......weirdddd
Old 07-26-2008, 11:39 PM   #7
Singe
BGDorcol
Singe's Avatar
I have the same problem, exept for me its the passanger side....execly the same thing as described above and mine also started wokring for a bit and then again it stoped...some one also told me its one of the these metal hooks inside the door and it got unhoocked from where its supposed to sit and let the doors lock and unlock so im not sure what the problem is either.
Singe is offline   Reply With Quote
Old 07-26-2008, 11:53 PM   #8
maroli
I have the same problem with my passenger door, only if I unlock or lock from the passenger door does it unlock/lock
but then, my handle is peeling away from the door, I think it may be the hook thing and not the actuator
maroli is offline   Reply With Quote
