Old 07-22-2008, 07:25 AM   #1
E36is
'OldSchool..'
E36is's Avatar
HID output.. not that great
Need some input on this issue i have.
just recently installed a HID kit into my car, here is the information on them.
ballast: slim version 35w. (digital)
Bulbs: h7 5000k
Headlight assembly: Depo ellipsoid (h7 bulb style)
Ive had them for 3 days now, and im just not impressed with the light throw or illumination on the road with them. I've tried re-aiming them thinking i may have the lights aimed high but they just arent throwing the light onto the road (in short, the light throw is scattered if that makes sense). I've compared them with another HID equipped e36 with 35w/6000k and theirs is considerably brighter and throw the light onto the road. Any help would be apreciated thanks.
E36is is online now   Reply With Quote
Old 07-22-2008, 08:15 AM   #2
Soldo
Soldo's Avatar
Are your headlights pitted? My headlights are snadblasted to hell and the light output suffers from it!
What kind of KIT you got in there?
Keven Soldo
Old 07-22-2008, 08:30 AM   #3
I'm using one of Ivan's kits and I have no problems. The throw is dependent upon your projector setup, and I don't think the H7 depo's are the greatest for that...
Old 07-22-2008, 08:40 AM   #4
Mickey Knox
[QUOTE=E36is;1179548]
QUOTE]
low beams should be H1, no? i am confused a little shouldnt these be projector headlights too?
Mickey Knox is offline   Reply With Quote
Old 07-22-2008, 08:59 AM   #5
E36is
'OldSchool..'
E36is's Avatar
answers:
no the headlights are not pitted, with my original setup with the halogens, the light output and spread was better than with the Hids wtf?!??!
Depos also came with h7 setup.
the HID kit i have is stated in original post.
Old 07-22-2008, 09:05 AM   #6
Better withOUT HIDs? That's not right at all. Don't know what to tell ya :S
Old 07-22-2008, 11:13 AM   #7
Gamite
Gamite's Avatar
Sound like the bulb is not lining up correctling inside the housing. Compare the HID bulb with the stock hallogen bulb, and see if the filament lines up with the HID output point correctly.
www.gamite.net
Old 07-22-2008, 11:52 AM   #8
vadim321go
vadim321go's Avatar
everything should be H1, not sure why you have H7 :S
Proud owner of a 95 325i
Old 07-22-2008, 12:26 PM   #9
^Some Depos came with H7 housings.
Old 07-22-2008, 01:04 PM   #10
E36is
'OldSchool..'
E36is's Avatar
thanks guys, ill check them out tonight and see if they are installed correctly. Im guessing the HID bulb should be centered in the projector housing? And would placing the HID bulb closer or farther from the inner projector provide me with improvement on the lighting dispursement and brightness?
Old 07-22-2008, 02:03 PM   #11
Dr. Flyview
"Mint"
Dr. Flyview's Avatar
Hmm I thought the depos with H7s were not projectors...
1998 BMW 328is - summer
1993 BMW 525i - sold
1994 BMW 325i - sold
1992 BMW 325i - gone
sold
Old 07-22-2008, 02:10 PM   #12
Boots R
Boots, not boost
Boots R's Avatar
Depo H7's:
Old 07-22-2008, 02:14 PM   #13
E36is
'OldSchool..'
E36is's Avatar
^^ those the ones. thanks Kevin
Old 07-22-2008, 03:11 PM   #14
v_bimmer
Jailbait FTW
v_bimmer's Avatar
try and check if the bulbs are inserted at the right angle, and check if they are not touching the metal inside the headlights!! thats what happend with my bulbs, they were put in at a wrong angle
Old 07-22-2008, 04:00 PM   #15
Hey rommel.
Send me a PM, i can take a look and make sure that they're in correctly. I'd be very surprised if they weren't, however, i'm happy to take a look.
The projection on the H7 depo's isn't as good as it is on the H1 depo's. (i have the exact same kit as you, except 4300K, in my lowbeams, they're H1 depo's)
