Old 07-21-2008, 12:05 PM   #1
Addict
Do these rotors look good?
From the pics, does it look like they're worth buying or do they look worn down for immediate replacement?
Imola Red / Imola Red ///M5
E60 SSK, Dice iPod, Illuminated ZHP knob, GT Custom Exhaust, BCR Coilovers
Past:
'01 330Ci Titanium Silver on Coral Red
'96 328i Jet Black on Black
Old 07-21-2008, 12:08 PM   #2
Hasselhoff
Hasselhoff's Avatar
They look pretty wizzed to me.
Hasselhoff is offline   Reply With Quote
Old 07-21-2008, 12:08 PM   #3
Addict
Crap, sorry about the massive filesize.
Past:
Old 07-21-2008, 12:09 PM   #4
Boots R
Boots, not boost
Boots R's Avatar
Why are you buying used rotors?
Old 07-21-2008, 12:09 PM   #5
DriveItSideways
waste of money, that rotor would cause huge vibrations.
Old 07-21-2008, 12:11 PM   #6
Steve@ASPTuning
How much do they want for them?
And No.
Looks like there's still some meat left on them, and probably from the looks of the lines created from the brake pads. It'll have to be machined out and leave you with even less meat. But you can't because their cross-drilled.
Its not recommended that you buy used rotors as brakes are the most important part of your vehicle. And those rotors look like its had a lot of play in its life....
Plus, there's no warranty in case of manufacturer's defect or warpage.
Hope that helps. I know if it was me,personally I wouldn't buy those for my E46.
Steve
ASPTuning
Steve@ASPTuning is offline   Reply With Quote
Old 07-21-2008, 12:11 PM   #7
vadim321go
vadim321go's Avatar
blank brembos cost 80 a piece....dont bother with drilled rotors ESP used ones!
Proud owner of a 95 325i
Old 07-21-2008, 12:17 PM   #8
DANIMAL
TYRE ETR
DANIMAL's Avatar
Espically cross-drilled. Take a look at Dave's(98Dinan3) rear rotors next time you see him. Besides being very well worn, as those used ones are, there are stress fractures moving outwards from the cross drilled holes.
eg.
And I would imagine much worse fractures on a rotor that has been that well used.
DANIMAL is offline   Reply With Quote
Old 07-21-2008, 12:19 PM   #9
Addict
I don't need to be preached on the OMFG DRILLED ROTORS CRACK! But thanks
Kev, it's used BBK and I agree it looks pretty worn...
Vadim, I know about OE-sized Brembo blanks, I just wanted to explore some "used" BBK options instead.
Past:
Old 07-21-2008, 12:35 PM   #10
King Luis
The King.
King Luis's Avatar
buy new pads, rotors, and fluid and then buy used calipers/hardware. but make sure it's in good condition. i'd shy away from used rotors. you don't know if they are warped until you install them. plus those rotors look like they got some pretty bad grooves.
2004 Silver Gray M3
Old 07-21-2008, 12:36 PM   #11
DANIMAL
TYRE ETR
DANIMAL's Avatar
Not trying to preach, just stating why I would not do it and backing it up with fact. You cant go on a public forum and not expect peoples opinions. Use whatever you want I don't really care, just seems to me like a waste of $$. Unless your buying the kit at a really good price, then it might be worth it just for the calipers/brackets.
Old 07-21-2008, 12:42 PM   #12
come on man, you shouldn't even be thinking of buying used brake parts.
Dare I squeeze
Old 07-21-2008, 12:44 PM   #13
Steve@ASPTuning
Okay guys calm down.... haha we don't need to flame him about buying used rotors. I think he gets the point
Steve
ASPTuning
Old 07-21-2008, 12:54 PM   #14
Addict
It's the pricing that has got me thinking . For sure I would prefer to just grab everything but the rotors and pads - just wanted your opinions on what life those rotors seem to have left.
I really want just the calipers/brackets. Next step is to find out how much new rotors and pads would cost and see if I can convince the seller to part the calieprs/brackets.
I haven't, and wouldn't buy used brake parts (rotors/pads) unless they were practically new. In case of used BBKs, I'm all for the hardware not the rotors/pads.
Past:
Old 07-21-2008, 01:28 PM   #15
maroli
OMFG CROSS DRILLED ROTORS CRACK
I guess I'm in trouble then cause I'm getting a set
but seriously, they don't always crack, I mean tons of manufacturers use them, like Porsche and Mercedes. Unless you're tracking or ride the brake pedal like a mofo, I think you're good with 'em. Not those of course, but in general
maroli is offline   Reply With Quote
