Old 07-15-2008, 02:22 AM   #1
Carlos12
Carlos12's Avatar
Question about Rims/tires
sup guys just a small question that im doubting..
I own a 325i 94 and currently still have the stock tires on them..
The car hasnt been lowered or anything.
question? Will a 19" staggered rims with rubber fit or will there be any minor conflicts?
Carlos12 is offline   Reply With Quote
Old 07-15-2008, 04:34 AM   #2
if you're worried about rubbing, run 215/30/19
they're actually a little smaller than the wheels/tires you have now/
Old 07-15-2008, 09:40 AM   #3
And if you're not lowered, you shouldn't have much of a problem.
Old 07-15-2008, 10:17 AM   #4
carjoe
carjoe's Avatar
double check your offset. Not sure what it should be but it's important too!
93 325is - sold!
2000 540ia- sold!
Old 07-15-2008, 10:32 AM   #5
Boots R
Boots, not boost
Boots R's Avatar
19's will fit with the right offset.
Old 07-18-2008, 02:56 AM   #6
Carlos12
Carlos12's Avatar
what do u mean offset?
i just did a check on my tires/rims and its all at 225/50R16 92V
and still abit more space for tires to make a turn... so since those fit in my car...should i still look something like 225/50/19 or it has to be alittle less...can someone gimi options or if u own a 94 325i and u manage to fit 19" without a problem..let me see pic if u dont mind and stats of the size. and also if i could get a size range from what to what i should be looking to get..that would be great. ( reminder my car hasnt been lowered or anything..its all as is)
Old 07-18-2008, 01:30 PM   #7
225/50/19 will be hideously gargantuan!
You will need to stay within your stock diameter, so probably 225/35/19. Wheels should be around ET40 if they're 8 or 8.5" wide. Unless you drop the car heavily and stiffen up the suspension to help with rubbing, it may not look right. Personally, go with 18s if you want to play it safe.
Old 07-18-2008, 01:33 PM   #8
Carlos12
Carlos12's Avatar
i plan in gettin staggered...so 225/35/19 for front and what about rear?
Old 07-18-2008, 01:42 PM   #9
Depends on the width and offset of the rears. Running wide 19s out back is very, very tough.
Old 07-18-2008, 01:43 PM   #10
saint166
without lowering your car u wont have any rubbing they just wont look very good . your car and its up to u but i doubt u will be happy with 19's . i recently did 18" csl reps with h&r race springs and even the 18's look big on my car
saint166 is offline   Reply With Quote
Old 07-18-2008, 08:30 PM   #11
Eurotakeover
BMW Obsessed
Eurotakeover's Avatar
17's or 18's. 19's look weird unless the car is slammed.
Eurotakeover is offline   Reply With Quote
Old 07-18-2008, 11:46 PM   #12
trd_mr2
donk
trd_mr2 is offline   Reply With Quote
Old 07-20-2008, 12:07 AM   #13
carjoe
carjoe's Avatar
To get another set of rims, I'd do 18's. 17's look good but I think the proportion of an 18 would look better.
93 325is - sold!
2000 540ia- sold!
