Old 07-17-2008, 08:17 PM   #16
noid
noid's Avatar
Im not quite sure what the minimal compression for an b27 is but i know for the b25 mine is around 180. However thats besides the point. Whats important is the variance between the cylinders and that all cylinders have compression. It seems by your numbers that the engine should still be able to run smoothly (not like a diesel).
If i were you i would use lucas injector cleaner or seafoam to see if that will clean up the insides.
Old 07-17-2008, 09:18 PM   #17
slimjim
Almost Sideways
can u film it and post a vid?
Old 07-17-2008, 10:16 PM   #18
BRAD 82
BRAD 82's Avatar
Send a message via MSN to BRAD 82
You want me to film the car when it starts and while running?
BRAD 82 is offline   Reply With Quote
Old 07-17-2008, 10:33 PM   #19
LeftRights
Leftrights
TUNE UP! 1st trust me
LeftRights is offline   Reply With Quote
Old 07-17-2008, 11:01 PM   #20
5thseries
biggerthen3
Check out your plugs or your distributer, and your wires
The plugs may be used all up
Look at your distributer for any kind of build up
If the car successfully turns over but idles like crap, then its the plugs possibly.. check those out.
5thseries is offline   Reply With Quote
Old 07-18-2008, 01:02 AM   #21
noid
noid's Avatar
Its not the wires. I put on my spare wires while brandon still had it and it was still the same.
Old 07-18-2008, 03:57 AM   #22
mirek
mirek's Avatar
That's some pretty low compression, 100? eek. should be ~180 through all 6
Old 07-18-2008, 08:51 AM   #23
e24_635csi
still wants a turbo...
e24_635csi's Avatar
maybe the cat is plugged, i picked up at 528e, and sounded the same way. had absolutly no guts, and sounded awful. once we cut the cat off, it ran fine. just a thought.
e24 635csi -e28 528e/m30b34 - e28 M5 - e34 M5 - e46 330xi M
e24_635csi is offline   Reply With Quote
Old 07-18-2008, 10:26 AM   #24
BRAD 82
BRAD 82's Avatar
ok will start with the tune and go from there! if that doesn't work then i will cut the cat off and see what happens then!
Thanks guys will keep you posted!
Old 07-18-2008, 10:28 AM   #25
BRAD 82
BRAD 82's Avatar
Granted that i have never done a compression test before and the kit i got wasn't a perfect fit in the sprakplug hole but it would appear that i got pretty close to the same result right the way accross.
I was more so looking for consistency. but i think once i do a tune up and clean her up a bit that should help.
Thanks,
Brad
Old 07-19-2008, 10:53 AM   #26
BRAD 82
BRAD 82's Avatar
Does anyone know where a tune up kit would be sold at a good price?
I went to lakeside motors yesterday and mike said that if you are going to do a tune you have to do a valve adjustment.
Is this true? 280$ a good price?
Old 07-19-2008, 01:11 PM   #27
noid
noid's Avatar
you dont have to do a valve adjustment unless you want to. No part of the tune up requires you to take off the valve cover.
Old 07-19-2008, 04:42 PM   #28
mirek
mirek's Avatar
280$ for a valve adjustment? you can do that yourself.
Old 07-19-2008, 08:28 PM   #29
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
Valve adjustment on M20s only affects valve noise, not how shitty the car runs. Unless there is a much larger problem, he's basically try to **** you over. For $280 you can get a complete mint running eta engine.
Old 07-20-2008, 12:35 AM   #30
mirek
mirek's Avatar
And don't go cutting your cat off just because you suspect it's clogged.
Why not just take it to the bimmersport, they should be able to diagnose it pretty quick, b
