Old 07-07-2008, 03:31 PM   #16
chromius
chromius's Avatar
Originally Posted by BigD View Post
JFYI my crappy tire fuel hoses say 12 bar.
Good stuff...guess they changed them since I last checked.
Old 07-07-2008, 04:14 PM   #17
ecuconnection
ecuconnection's Avatar
so for my brake line repair it's like a 2 inch bad section and I dont want to replace the whole line... can I flare the line and use rubber hose rated for brake line use and just double clamp? or do do I need to use presure fitings?
Old 07-07-2008, 06:57 PM   #18
chromius
chromius's Avatar
I don't think hose clamps will do for a brake line, you'll want to put a proper 'AN' fitting on.
Old 07-07-2008, 07:31 PM   #19
ecuconnection
decided Im going to replace the whole line... I took a good look at everything and it's actulay much easyer then I thought it would be ... all the lines are clearly visible surprizingly... I bet it's not like that on the 540 haha
Old 07-07-2008, 11:15 PM   #20
carjoe
carjoe's Avatar
Keep practicing Barry...I'm gonna pay you in car parts to start working on mine!
93 325is - sold!
2000 540ia- sold!
Old 07-08-2008, 08:32 AM   #21
chromius
chromius's Avatar
Yeah it is. They're all visible. Most cars have them out in the open like that.
Old 07-08-2008, 08:35 AM   #22
ecuconnection
oh well then ... I'm sure that would be the last thing to go on your car anyway
Old 07-08-2008, 08:37 AM   #23
ecuconnection
yup im getng prity good with the e36... I just have to remember to titghten all the bolts up while swet is driping in my eyes
Old 07-08-2008, 08:40 AM   #24
chromius
chromius's Avatar
Yeah, instead it's just repetitive power steering pump and cooling system breakage
Old 07-08-2008, 10:14 AM   #25
Nascar318is
Nascar318is's Avatar
I don't know man... I'd go full lines, not rubber ones, after what happened with the ford and my super rubber line... never again. If you install all that stuff by yourself, spend the money on the steel lines... And the bunder is around $15 at CT, you can do 4 different sizes.. My buddy did his fuel(all of them) and rear brake lines.. with the bender and some line..
I agree with Joey, keep practising, cause I'm starting to smell gas....
Old 11-14-2008, 10:27 AM   #26
AWD_Guy
AWD_Guy's Avatar
Yes, newb bringing this from the dead....
I just re-did the fuel lines on my e30, I bought the lines from Otto's, think it came out to $80 for the feed and return lines...
Relatively simple install, had a hard time undoing the old line where they were rusted, but that was the hardest part. Suggest anybody looking at redoing their lines to take a look at the oem kit. probably a little more money than flaring your own, but its was a straight bolt in procedure, worked out great
AWD_Guy is offline   Reply With Quote
Old 11-14-2008, 12:06 PM   #27
Were they already bent?
Old 11-14-2008, 12:44 PM   #28
AWD_Guy
AWD_Guy's Avatar
Yup...like I said, it was a direct bolt in. Take old ones out, put new ones in, voila, new fuel lines.
EDIT: All i did was look up the part #'s on realoem.com and gave those to the parts guy at Otto's.
Old 11-14-2008, 01:02 PM   #29
I only ask because brake lines are straight, not pre-bent, so I assumed they'd be the same. Good info, thanks!
Old 11-14-2008, 01:36 PM   #30
AWD_Guy
AWD_Guy's Avatar
Im not sure if they sell the same kind of kit for the brakelines...Im due though...I can be the test mule! Yay!
