Old 06-26-2008, 08:35 AM   #1
540i6
540i6's Avatar
BMW 540i Engine Problem
I have a 1998 BMW 540i and every time the engine is started, there's a loud clicking noise coming from one of the valves. Just curious if anyone has had this problem before or knows what it may be? Thanks!
540i6 is offline   Reply With Quote
Old 06-26-2008, 11:18 AM   #2
chromius
chromius's Avatar
does it just happen on startup or does it continue on while it's running?
if it continues while it's running, then it could be a collapsed hydraulic lifter.
If it's just at startup, it could be lack of oil, or just simple vanos rattle.
Old 06-26-2008, 11:45 AM   #3
540i6
540i6's Avatar
It continues while running. If it ends up being a collapsed hydraulic lifter should I replace them all?
Old 06-26-2008, 07:54 PM   #4
Junaid
it could be coolant in the block which is letting the oil lubricate and causing friction
Junaid is offline   Reply With Quote
Old 06-26-2008, 07:58 PM   #5
martinM5
could be a lifter but could also be worn out timing chain tensioner, once the plastic is worn out enough it runs out of the ability to keep tension on the chain and the chain makes noise while slapping the tensioner. But that would be faint on start up, then get worse as the oil heats up, the hotter the oil gets the more the oil pressure drops.
2009 BMW 335i Coupe Msport LeMans Blue on Sexy Saddle
2016 X3 28d Msport SpaceGrey on Saddle
martinM5 is offline   Reply With Quote
Old 06-27-2008, 11:31 AM   #6
540i6
540i6's Avatar
Would anyone know how much this would roughly cost? Should I take it to the dealership and have them fix it? I currently take my car to Engineered Automotive and i think there a little more expensive than the dealership!
Old 07-02-2008, 05:44 PM   #7
europrince
take it to RMP. they'll be straight with you. I had a similar noise that came from the front of both banks....probably a different issue than yours.
Old 07-03-2008, 09:57 PM   #8
bimmerjoe
Yagerbombs/skanks
bimmerjoe's Avatar
this happens to me just when the car starts after it starts the noise immediatly goes away.
1999 323i-sold
2001 540i M- Sport
bimmerjoe is offline   Reply With Quote
Old 07-07-2008, 09:43 PM   #9
europrince
get that shit checked out, buddy.
Old 07-08-2008, 09:37 AM   #10
540i6
540i6's Avatar
Started her today and the sound magically went away. That deffinitely makes my bank account real happy! Thanks guy's!
Old 07-08-2008, 09:48 AM   #11
chromius
chromius's Avatar
Self repairing problems are always the best.
