Old 06-24-2008, 10:50 PM   #1
330DTM
Cinematographer
330DTM's Avatar
Help: Metal Clinking Sound Over Bumps?
For a while I've been noticing that whenever my car goes over bumps (the usual impurities of the road, so small or big bumps), the right side is making a metal clinging noise. It sounds like something is loose.
However, when I drove over a same section of road again, remembering where the small bumps were, I would step on the brakes lightly to midly and as the car goes over the small bump the sound is gone.
I was thinking it had to be coming from the brakes, so maybe the caliper or pads? What could it be? I tried to check if it was coming from the handbrake by pulling it up a click and another after by driving around but no luck.
-=Slow In Fast Out=-
Old 06-24-2008, 11:04 PM   #2
maroli
check if rear shock mount or spring is broken. one of the tops of my spring was broken when I got my car, made a kind of clanking over bumps
maroli is offline   Reply With Quote
Old 06-25-2008, 12:26 AM   #3
Rear brake pad? My car does this on a normal basis (what you described)...
Old 06-25-2008, 02:01 AM   #4
Bliss
Administrator
After you installed your coilovers did you tighten the large adjusting rings well? Sometimes they can become loose and make a metal sounding rattle. Not sure if you changed your brakes Mike, but some aftermarket brake pads may make a rattle too (Crappy "anti-rattle clips").
For maXbimmer decals, please email info@maxbimmer.com
Old 06-25-2008, 07:33 AM   #5
Gamite
Gamite's Avatar
maybe brake pad clips like bliss said.
www.gamite.net
Old 06-25-2008, 08:12 AM   #6
Soldo
Soldo's Avatar
Had the same problem with my car. Sound went away when brakes were applied. I've narrowed it down to a loose component in the rear disc drum.
Keven Soldo
Old 06-25-2008, 08:31 AM   #7
BigD
the misanthropist
BigD's Avatar
This gets my vote too, probably fell out or you left it out (or didn't put in right)
Old 06-25-2008, 08:35 AM   #8
Nascar318is
Nascar318is's Avatar
X3 My rattle was from that Shim(AKA anti rattle clip) One was missing..
Old 06-25-2008, 08:39 AM   #9
Gamite
Gamite's Avatar
they can get bent out of shape to the point where they're not tight anymore. Just bend them back.
www.gamite.net
Old 06-25-2008, 08:59 AM   #10
Michel
Michel's Avatar
I get the same exact noise in my acura. For me its a combination of a ceased rear caliper and faulty clip on my break pad.
Old 06-25-2008, 09:05 AM   #11
Time for a quick brake inspection, while your in there lube the sliders and clean up the mating surfaces. (ie, brake service)
Old 06-26-2008, 01:16 AM   #12
330DTM
Cinematographer
330DTM's Avatar
Thanks for the response guys.
Well it never made the noise till I got my Inspection II & brake fluid flushed at Bimmersport almost 3 weeks ago. They did a great job, but probably something they missed.
I just wanted to know if it's something that should be fixed as I have a lapping event coming up on Tuesday and I believe they inspect the cars prior to letting us drive on the track.
Neither Bimmersport nor RMP are open on Sat so I'll have to find a shop this weekend
Old 06-26-2008, 08:26 AM   #13
Gamite
Gamite's Avatar
mike, bring it by my house, I'll let you knwo if it's the caliper clip or not.
www.gamite.net
