Old 06-18-2008, 11:38 AM   #1
91momoE30
Compression test.
Hey guys,
I just picked up a tester but I dont know how to do it on a 91 318Is M42.
Can somebody tell me what fuses I need to pull or what I need to disconnect,
Also what is the service limit on these motors and what should I expect.
Thanks,
91momoE30 is offline   Reply With Quote
Old 06-18-2008, 08:32 PM   #2
e30jones
I'm not sure whether fuses/procedures are the same for 318is's but maybe someone else will confirm.
1. Pull fuse 11 (for fuel pump) and then disconnect the coil wire (or the one that goes to the coil pack on the 318is).
2. Thread compression tester into sparkplug hole
3. Go to driver's seat, and mat the gas pedal to open the throttle.
4. Then crank the engine over until the gauge needle doesn't go any higher. (~3-4 revolutions probably)
Repeat for remaining cylinders.
I think that 2.5i engines should be around 150psi, so I would guess slightly higher would be expected on the higher compression m42, but it is more important to have little variance between cylinders. You usually don't want to have any more than 10% (I think?) difference between each cylinder, less is better.
e30jones is offline   Reply With Quote
