Old 06-16-2008, 04:55 AM   #1
doogee
Stance is Gay.
doogee's Avatar
Thumbs down Strange Sound
I just noticed today driving with my windows down that there is a strange sound coming from down below. I searched but didn't find anything.
Must have something to do with the transmission:
-Sounds like crickets
-Not very loud
-No sound with clutch depressed
-All gears
-Can't hear it at idle in neutral
-Doesn't get louder in different gears, just the same noise while accellerating throughout all gears.
Any ideas? Doesn't sound "alarming" or anything, but want to check it out.
Dakar M3 Track Build Thread
Old 06-16-2008, 12:01 PM   #2
luker0
Likely a loose heat shield. There are several on the car.
luker0 is online now   Reply With Quote
Old 06-16-2008, 12:30 PM   #3
Eurostyle
Eurostyle's Avatar
You missed the "-No sound with clutch depressed" part...
Most likely clutch/transmission...
Eurostyle is online now   Reply With Quote
Old 06-16-2008, 12:35 PM   #4
sproule905
sproule905's Avatar
didn't you JUST pick up this ride!
did you not test drive it... looks like the owner got a away with one of ya there buddy!
shatty!
Old 06-16-2008, 12:39 PM   #5
doogee
Stance is Gay.
doogee's Avatar
i test drove it, this just started happening a week later. It's not very noticeable.
Sometimes it doesn't even make the sound. I'm going to let it go unless it becomes common.
Old 06-16-2008, 12:47 PM   #6
Eurostyle
Eurostyle's Avatar
Very bad approach to things, if there is any sign of a problem it wont fix itself...Get it checked at early stage, it will gost you way less and avoid more damage...
Old 06-16-2008, 01:50 PM   #7
JUICY J CAN'T
propr'one's Avatar
throwout bearing?
hid headlights
Old 06-16-2008, 01:55 PM   #8
Boss17
Boss17's Avatar
Very well put. I don't understand people that put shit like that off? If you hear a weird noise, have your car checked out and fix it before the problem gets worse and consequently more costly.
2012 Mercedes-Benz C250 Coupe-PRESENT
1996 BMW 328is- SOLD
1998 Mercedes-Benz E430- SOLD
1990 Ford Probe Turbo- SOLD
Boss17 is offline   Reply With Quote
Old 06-17-2008, 12:07 AM   #9
doogee
Stance is Gay.
doogee's Avatar
will get it checked out this week
Old 06-18-2008, 11:25 PM   #10
doogee
Stance is Gay.
doogee's Avatar
So I got underneath, there were loose heatshields and the driveshaft was rubbing on some insulation. Fixed all that up and everything looks good but the sound is there.
It goes away in gear even with the slightest bit of pressure on the clutch. There is a tad bit of "play" in the pedal but before it becomes harder to press and in that area, the sound goes away. It doesn't take much.
Anymore ideas before I take it to a shop?
Old 06-18-2008, 11:48 PM   #11
98Dinan3
98Dinan3's Avatar
Originally Posted by propr'one View Post
throwout bearing?
i betcha you're right...
Old 06-18-2008, 11:51 PM   #12
Eurostyle
Eurostyle's Avatar
^^^Most likely...
Old 06-19-2008, 01:27 AM   #13
doogee
Stance is Gay.
doogee's Avatar
So any recommendation for where I should take it to get looked at? Or is a local shop good enough?
Old 06-19-2008, 01:47 AM   #14
Eurostyle
Eurostyle's Avatar
Local shops wont do it IMO...Seen too may people getting burned...Take it to a reputable BMW shop...Bimmersport is the place on top of that list...
Old 06-19-2008, 01:55 AM   #15
doogee
Stance is Gay.
doogee's Avatar
Alright sounds good. I'll have to take it in sometime soon
Thanks for the advice.
