Old 06-11-2008, 04:18 AM   #1
doogee
doogee's Avatar
Exclamation Hadr to shift into 2nd
So I just picked up a 98 328is last friday.
Great car, I love it.
But the last 2 days, it's been sort of difficult to shift from 1st to 2nd.
Everything else feels alright.
The clutch feels fine. If the car isn't moving and I move in between gears with the clutch it, it's very smooth. Different story when the car is moving though.
I experimented by letting the clutch out a little while stationary and then shifting and it's the exact same feeling as when I'm driving.
Any help is greatly appreciated. Did some reading and found a good place to start would be to flush the brake/clutch fluid.
Old 06-11-2008, 05:53 AM   #2
98Dinan3
98Dinan3's Avatar
you'll also want to remove the clutch delay valve from the end of the rubber clutch line while you're at it...
Old 06-11-2008, 12:29 PM   #3
v_bimmer
Jailbait FTW
v_bimmer's Avatar
yeah ive been having the same problem, i have problems shifting into all gears except for 5th!! when the car is hot, its impossible to drive!! next thing i might do is flush the clutch fluid, because tranny fluid flush didnt help much
Old 06-11-2008, 12:51 PM   #4
doogee
doogee's Avatar
People on bimmer forums are telling me my synco's are probably messed up and may need a tranny rebuild.
Old 06-11-2008, 03:06 PM   #5
bigfeller
Propeller Head
bigfeller's Avatar
Gear oil
Change your transmission gear oil to Royal Purple or some other synthetic as well. That will help.
bigfeller is offline   Reply With Quote
Old 06-11-2008, 03:25 PM   #6
mirek
mirek's Avatar
before you take it to a place to rebuild your tranny, have a good mechanic look at it, take it to Bimmersport (check sig)
Could be something simple like a worn mount,
Old 06-11-2008, 03:31 PM   #7
98Dinan3
98Dinan3's Avatar
forget a rebuild.... if it comes down to it, it will be cheaper to get a low km used tranny installed.
Old 06-11-2008, 04:52 PM   #8
againstallodds
where exactly is that located and how would i do it myself? like wat are the steps? and also, by removing that, wat difference does that make?
againstallodds is offline   Reply With Quote
Old 06-11-2008, 11:53 PM   #9
doogee
doogee's Avatar
Removing the CDV will allow the clutch to engage quicker. The CDV "eases" the clutch in which causes more wear.
Deleting it makes for quicker shifts and a longer lasting clutch.
Google "e36 CDV delete"
Old 06-12-2008, 12:42 PM   #10
againstallodds
thanks.
Old 06-16-2008, 04:59 AM   #11
doogee
doogee's Avatar
Put a new knob on and shifter seems smoother? It has a longer throw to it. Strange.
It had a crappy Canadian Tire knob on it so I replaced it with the M-Illuminated knob and knob it feels great.
Might just be a fluke.
Dakar M3 Track Build Thread
