Old 06-08-2008, 07:37 PM   #1
doogee
Stance is Gay.
doogee's Avatar
Exclamation High beams don't always work
Okay so I just picked up a 5-Speed 98' 328is.
I noticed that the high beams don't always work. I'll try them, they won't turn on, but randomly I try again 30 mins or so later and they'll work.
No daytime or night time light problems.
When the high beams do work, all 4 lamps are lit. Is that normal?
Need some info on this, thanks!
Old 06-08-2008, 08:12 PM   #2
98Dinan3
98Dinan3's Avatar
Yes, all 4 will light when the high beams are on. Your fogs will also turn off when the high beams are activated... although technically illegal that's a five minute fix to remedy. As far as the intermittent light issue, you're gonna have to check all the connections on that circuit. It's possible a wie is frayed, or a connector is loose...
Old 06-08-2008, 10:44 PM   #3
doogee
Stance is Gay.
doogee's Avatar
thanks for the help, some others have recommended replacing the relay too.
Old 06-08-2008, 11:58 PM   #4
Dr. Flyview
Formerly Flav_cool
Dr. Flyview's Avatar
Send a message via MSN to Dr. Flyview
Don't be offended or anything, just make sure the headlight switch is in the last position: some of the first positions may not allow the high beams to come on.
1998 BMW 328is - summer
1994 BMW 325i - daily
1992 BMW 325i - totaled
sold
Dr. Flyview is online now   Reply With Quote
Old 06-09-2008, 09:18 AM   #5
ShortShifter
Sex Wagon
ShortShifter's Avatar
Your light setting needs to be to the far right position for your highbeams to stay on via pushing the stick towards the front of the car. Pulling the stick towards you should work no matter what setting you have your lights set to.
Originally Posted by alpine86 View Post
Do we really need an Ipad???
Originally Posted by BigD View Post
Only if you have an iVag.
ShortShifter is offline   Reply With Quote
Old 06-15-2008, 09:57 PM   #6
doogee
Stance is Gay.
doogee's Avatar
Yeah I've tried with the lights in the last position, and everything.
No go, they won't come on at all anymore.
Dakar M3 Track Build Thread
Old 06-15-2008, 10:20 PM   #7
doogee
Stance is Gay.
doogee's Avatar
Just found this part of the headlight assembly on the highbeam side.
Wondering what it is?
