Old 06-06-2008, 11:43 AM   #1
325ixE30
325ixE30's Avatar
E30 Do It Yourself Articles
I love this site.
http://www.bimmerdiy.com/dir/e30
Tons of great articles and step by step instrctions for the E30 enthusiast in all of us.
Below is a list of the articles. Some have pictures, most don't
Maintenance - BMW E30 DIY
Replacing Your Differential Fluid
Brake Pad Bedding In Procedure
Ignition System Tune
Timing Belt Replacement
Miscellaneous - BMW E30 DIY
BMW Integrated Garage Door Opener
BMW On Board Diagnostics
BMW Designation FAQ
Tire Size Calculator
Hot Rodding Your Floor Jack
Street Dyno!
All About Gasoline
Synthetic Oil or Not?
All About Motor Oils
Welding Primer & Review
BMW Parts Catalog
Idle Speed Troubleshooting
Front Wheel Bearing Replacement
... More Miscellaneous - BMW E30 DIY
Engine / Mechanical - BMW E30 DIY
A/C Compressor Retrofit & Upgrade
Valve Adjustment Made Easy
Motor Mount Replacement
Aux Fan Resistor Replacement (Bosch)
Oil Control Valve Gasket Leak (M20/B25)
Passenger-Side Water Leak
Electrical - BMW E30 DIY
E30 Chip Install
Blinking Sidemarker Modification
Replacing Service Indicator Board Batteries
OBC Lamp Replacement
Front Speaker Installation
Rear Speaker Installation
E30 LED Key Conversion
All Red Tail Lights
Interior - BMW E30 DIY
E30 Instrument Light Replacement
E30 Gauge Face Replacement
Dashboard Swap
Fischer Cup Holder
Leather Restoration
Carpet Dying
Exterior - BMW E30 DIY
Replacing your BMW Roundel Emblem
Blacking Out Your Chrome Trim
All Red Tail Lights
E30 "is" Lip Spoiler
Lighted Rearview Mirror Retro-Fit
http://e30.bmwdiy.info/bumper-adjust/index.html
Side Mirror Repair
Sunroof Adjustment
Exhaust - BMW E30 DIY
Building an In-Dash Air-Mixture Monitor
Brakes - BMW E30 DIY
Painting Your Calipers
BMW E30 3-Series Cross-Drilled Brake Rotor Upgrade
Rear Brake Disc Replacement
Replacing Front Brake Discs
Bedding In New Pads And Rotors
Lighting - BMW E30 DIY
All Red Tail Lights
CELIS Light Source
Xenon Bulb And Ballast Installation (Ellipsoids)
Independent Fog Lights
Smoked Sidemarkers
Detailing / Painting - BMW E30 DIY
Detailing Your Car
Wheel Curb Rash Removal
Painting Your Intake Manifold
Painting The Engine
Using Porter Cable Orbital Buffer
Cooling - BMW E30 DIY
Coolant Temp Sensor Replacement
Fuel Delivery - BMW E30 DIY
Oxygen Sensor Replacement E30
Fuel Filter Replacement
Fuel Injector Cleaning
Stability / Suspension - BMW E30 DIY
E30 Rear Sway Bar Bushing Replacement
E30 Rear Sway Bar Drop Link Replacement
Front Springs and Shock Replacement
Rear Springs and Shock Replacement
Replacing Rear Shock Mounts
Front Suspension Bushing Overhaul
M3 RSM Retrofit With Z3 Reinforcement Plates
Transmission / Drive Shaft - BMW E30 DIY
Seats / Doors - BMW E30 DIY
Rear Seat Removal
Leather Restoration
325ixE30 is offline   Reply With Quote
Old 06-06-2008, 04:50 PM   #2
BimmerboyPH
BimmerboyPH's Avatar
Thanks, awesome find
88 325is- written off
89 735i 5 spd- traded
89 325is m50 swap- sold
92 325is- sold
97 328is- sold
00 Land Rover Disco- sold
07 328i- sold
84 325e- track car, in progress........ SOLD!
87 325is- FOR SALE
98 328is- Current Daily
BimmerboyPH is offline   Reply With Quote
Old 06-06-2008, 07:15 PM   #3
woofster
That's a great website. It was the first one I found and bookmarked when I bought my E30!
woofster is offline   Reply With Quote
