Old 06-04-2008, 11:34 PM   #1
91momoE30
C/E/L... Need local Help please.
Hey guys,
I have a check engine light... and I have no way of checking it.
Im also new to bimmers so I dont know the tricks..,
Anyone in the area willing to help me out?
Let me know,
Thanks Alot.
91momoE30 is offline   Reply With Quote
Old 06-05-2008, 08:13 AM   #2
supernaught
supernaught's Avatar
You can grab a Haynes manual from crappy tire.
You can find manuals online, or download them.
Look for the pedal test. It will give you a code, but you need the codes anyways to understand. Look at e30tech.com, they have a sticky thread for manuals.
There should be lots of guys in your area though. Not many will work for free. Load your beer fridge and more should stop by though.
Old 06-05-2008, 03:46 PM   #3
91momoE30
Sounds good to me, I wouldnt mind buying a few beers.
Thanks,
Old 06-05-2008, 03:50 PM   #4
noid
noid's Avatar
Bring it by here and ill do the stomp test for you. PM me.
Old 06-05-2008, 09:19 PM   #5
91momoE30
I got the 1221 o2 sensor c,e,l.
Is this a commen issue for the e30? it's a 318i by the way.
Thanks,
Old 06-09-2008, 11:38 PM   #6
91momoE30
I keep popping fuse #23 for some reason...
Does anyone know what that fuse is for?? and possble fixes?
Thanks,
Old 06-10-2008, 07:45 AM   #7
noid
noid's Avatar
Look in the owners manual if you have one. All the fuses are labeled in there. If its the same for a 325i then i can check for you later. Most likely cause of you popping fuse 23 is probably because of a short somewhere.
Old 06-10-2008, 08:41 AM   #8
supernaught
Headlight switch(the On/Off not the Hi/Lo).
From Fuse 23, power into switch - then splits to power head lights, fog lights, and parking lights(red and yellow corners too)
Do ALL of your lights work when you turn them on?
Put in a new fuse and Pull on your lights. Check the Fuse. It will be F#$Ked.
You have a short somewhere. Get a meter out and start at each light connector. Pull the connector off and check for shorts(continuity) between each terminal. Make sure the Knob is pushed in when you test this. If you find a short, keep looking, there might be more than one, or you might be seeing the same short on 2 different connectors.
Do this, get beck to us.
