Old 06-02-2008, 02:26 PM   #1
BimmerboyPH
BimmerboyPH's Avatar
Help! Car is almost stalling!!!!
Hey guys,
I finally got my new E30 plated and on the road on saturday. About half way through the day today i noticed a warning light flash on then off, but I never got a chance to see what one it was. When i got closer to my destination, the light came back on and it was the check engine light!! I pulled into the parking lot and left it running. I gave it a bit of gas and the light went out, but then the revs dropped below 500 and it sounded and flet as though it was going to stall, but then the revs jumped back up to the normal idle.
Anyone had this problem or something similar? My best guess is it is fuel or air related, but im not sure. Thoughts?
Phil.
88 325is- written off
89 735i 5 spd- traded
89 325is m50 swap- sold
92 325is- sold
97 328is- sold
00 Land Rover Disco- sold
07 328i- sold
84 325e- track car, in progress........ SOLD!
87 325is- FOR SALE
98 328is- Current Daily
BimmerboyPH is offline   Reply With Quote
Old 06-02-2008, 02:33 PM   #2
elroy
vaccum leak?
elroy is offline   Reply With Quote
Old 06-02-2008, 02:37 PM   #3
Sounds like a vacuum leak to me. Check all the hoses around the intake for splits or disconnections.
Old 06-02-2008, 05:50 PM   #4
noid
noid's Avatar
bring it by ill take a peek if you want
Old 06-02-2008, 05:51 PM   #5
mirek
mirek's Avatar
check engine light still on? stomp test to find out what it is.
Old 06-03-2008, 02:52 PM   #6
Ej_Red
Is this a 318 or a 325? Check your fuel pressure first. Don't guess.
Sounds like a fuel issue to me.
Ej_Red is offline   Reply With Quote
Old 06-04-2008, 11:36 AM   #7
87325I
E30 enthusiast
oxygen sensor?
87325I is offline   Reply With Quote
Old 06-04-2008, 11:53 AM   #8
o2 wouldn't make the car stall or stumble. Fuel or air would though. Is the OP even reading this? What have you found?
Old 06-04-2008, 01:48 PM   #9
BimmerboyPH
Well so far the problem has gone away. The only thing i can conclude is the heat and humidity the other day had an affect. For now im gonna leave it till the light comes on again, then figure out what fault code it is.
92 325is- sold
97 328is- sold
07 328i- sold
87 325is- FOR SALE
Old 06-04-2008, 02:01 PM   #10
What year / model is it? It may store the code if it's a mid 88+ model that you can recall with the stomp test.
Old 06-04-2008, 09:43 PM   #11
BimmerboyPH
Its an 1988 325is.
92 325is- sold
97 328is- sold
07 328i- sold
87 325is- FOR SALE
Old 06-04-2008, 09:46 PM   #12
If its past production month of April it should have a 173 ECU which can do the stomp test. Try it out and see.
Pre-04/88 production 88 model year have the 153 which is the bastard redhead stepchild of ECUs. It doesn't do the stomp test.
Old 06-05-2008, 10:30 AM   #13
The Question
What exactly is a Stomp Test?
The Question is offline   Reply With Quote
Old 06-05-2008, 12:56 PM   #14
I don't have the exact procedure here; google it: e30 stomp test
it involves turning the key, hitting the gas pedal 5 times and the check engine light will flash codes
Old 06-06-2008, 04:51 PM   #15
BimmerboyPH
Thanks, I'll look into it tomorrow when i get a break from work.
92 325is- sold
97 328is- sold
07 328i- sold
87 325is- FOR SALE
