Old 06-02-2008, 01:31 AM   #1
nyt
Can't feel the Bass on my E39 although set to max
The bass on my E39 is not loud even when the bass is set to max. When I increase the volume, the audio is very clear and loud but I don't get the heart bumping feeling you get when the bass is set to the max on other cars. I have been into other E39s and they were bumping when there base was set to max. I don’t think the problem is with my speaker since my speakers work fine. I was wondering if any one knows what I need to do to get base on my car. Is there anything on the amp that I need to thick to get the bass?
nyt is offline   Reply With Quote
Old 06-02-2008, 01:47 AM   #2
Boots R
Boots, not boost
Boots R's Avatar
you need a subwoofer. e39's do not have them stock.
Old 06-02-2008, 04:26 AM   #3
Dado 540
Dado 540's Avatar
i have the same problem on my E39....i thought they came with 2 woofers in a plastic enclosure right under your rear window. i think they are Nokia woofers. My Nissan is stock and it sounds like two 10'' in the back when bass is set to high, i cant believe they wouldnt put a woofer in a bimmer. originally when i got the car the guy had a system in the trunk and he took it out, so i thought that he did something to the stock amp.
Old 06-02-2008, 09:03 AM   #4
Gamite
Gamite's Avatar
well, that depends on what E39 you have
www.gamite.net
Old 06-02-2008, 09:42 AM   #5
Boots R
Boots, not boost
Boots R's Avatar
whoops, should have said NON-M5.
Speaking of which, why don't you buy an m5 subwoofer and install it?
http://cgi.ebay.com/ebaymotors/_Car-...em14023803060&
OEM ftw.
Old 06-02-2008, 09:54 AM   #6
Gamite
Gamite's Avatar
The M Audio subs are bigger than the ones boots posted. They're better, however, nothing beats aftermarket. I'm not entirely satisfied with their performance, but they'll have to do for now.
www.gamite.net
Old 06-02-2008, 10:28 AM   #7
Kal
maxRealtor
Send a message via MSN to Kal
the e39 sound system is shit
Kal is offline   Reply With Quote
Old 06-02-2008, 10:33 AM   #8
Gamite
Gamite's Avatar
most bmw sound systems are shit.
www.gamite.net
Old 06-02-2008, 11:22 AM   #9
Quack
Wheelman
Quack's Avatar
I have a 98 540i, I have a factory sub under the rear deck, I guess you guys don't have the upgraded sound system from the factory.
Old 06-02-2008, 11:31 AM   #10
europrince
^ Those BMW sound systems are made to give you crisp vocals in jazz and pop, crisp instrumental in classical music. They are not made for base thumping dance music. How many owners of a NEW 5 series do you hear pounding electronica or hip hop from a block away?
Old 06-02-2008, 11:59 AM   #11
chromius
chromius's Avatar
OEM ftw.
Some Non-M5 e39's had them too depending on what options you had.
Old 06-02-2008, 12:17 PM   #12
In my experience, I disconnected the factory subs and installed two 12" subs and an amp. With the rear seat down it sounded great, but with the seat up, I barely heard it. I felt it, but didn't hear it very much. Chromius mentioned last time I saw him that the rear of the e39 is riddled with sound absorption material, so that would make sense!
Old 06-02-2008, 04:41 PM   #13
Dado 540
Dado 540's Avatar
OEM ftw.
Mine is a 1998...this 2000 M5 Woofer system should be a plug in, in the 98's?
and if it did fit as a plug in, i would have to change the amp as well....right?
Old 06-02-2008, 04:44 PM   #14
Do you have the factory subs or not? DSP?
Old 06-02-2008, 04:58 PM   #15
uniter
spook
DSP Subs are alright man, I get pretty good bass from them There's a good reason you can't hear them from the outside of the car, the 5's are built for isolation.
Dinan ECU/CAI/Air Mass Meter. Rogue Engineering Clutch & Flywheel (First and Only), SSK, CDV delete. SuperSprint Exhaust, Resonator delete. F/R Eibach Sways. CF Hood
uniter is offline   Reply With Quote
