Old 05-22-2008, 09:17 AM   #1
adjei
head and tail light problem
i have checked the fuses and also tried changed the light blubs and still no light only my brake lights work drive headlight and rear light on drive side is out and have no idea what is going on.
adjei is offline   Reply With Quote
Old 05-22-2008, 10:55 AM   #2
Nascar318is
Nascar318is's Avatar
I would check the piece in which the light bulb sits, you may need to get in there with some sand paper to scuff it down for a proper connection. Or your board could be fubarred in some places. If the scuffing doesn't work, then check the electrical board in your rear tail lights to see if there's a connection messed up..
Old 05-22-2008, 12:08 PM   #3
Shoes R
Shoes R
Shoes R's Avatar
yeah my reverse lights dont work neither does my license plate lights?
2009 135i Alpine White on Coral Red Boston Leather come spring
Shoes R is offline   Reply With Quote
Old 05-22-2008, 12:25 PM   #4
Nascar318is
License is probablly corrosion, get 2 new bulbs and swap them.
Old 05-22-2008, 12:34 PM   #5
sproule905
sproule905's Avatar
you could have wires touching... ie the housing if deterioated
Old 05-22-2008, 04:35 PM   #6
adjei
ok il check it out all of these problems happened after i got my car painted the headlight bulb was smashed and was just hanging from its wiring
Old 05-22-2008, 07:26 PM   #7
BiggyAlex
Mmmm
headlight switch
BiggyAlex is offline   Reply With Quote
Old 05-24-2008, 11:16 AM   #8
adjei
the right side of the car works fine so what do you mean by headlight switch?
Old 05-24-2008, 11:03 PM   #9
Nascar318is
You guys cursed me, I left work last night and my buddy says "Hey your right side brake light is burnt out" WTF... A $2 bulb from CT fixed that. Just found it a big coincedence after posting on here
Did you manage to fix the problem?
Old 05-25-2008, 11:45 AM   #10
PROJECT_E36
x1 mabe a bad ground on the circut board or your connector might be corroded.
PROJECT_E36 is offline   Reply With Quote
Old 05-25-2008, 03:59 PM   #11
adjei
no fixed yet if try what project e36 and nascar said tho
