i have checked the fuses and also tried changed the light blubs and still no light only my brake lights work drive headlight and rear light on drive side is out and have no idea what is going on.
I would check the piece in which the light bulb sits, you may need to get in there with some sand paper to scuff it down for a proper connection. Or your board could be fubarred in some places. If the scuffing doesn't work, then check the electrical board in your rear tail lights to see if there's a connection messed up..
You guys cursed me, I left work last night and my buddy says "Hey your right side brake light is burnt out" WTF... A $2 bulb from CT fixed that. Just found it a big coincedence after posting on here
Did you manage to fix the problem?
x1 mabe a bad ground on the circut board or your connector might be corroded.
