Old 05-19-2008, 11:59 AM   #1
bimbert
ENGINE PROBLEM!? Scary!
hey all,
Model: 2002 325xi
Problem: After about 20 minutes on the highway I can feel the front of my car, possibly the engine SHAKING. When I take my foot off the gas pedal it goes away. But when I accelerate it starts to shake again. The shaking gets a little more violent as I continue driving, and when I exit to drive on urban roads I can still feel a little rumble. I park it and leave it for a few hours. When i drive back towards the highway it seems fine, but yet again, after 20 minutes on the highway it starts to shake again.
What's wrong with it??
bimbert is offline   Reply With Quote
Old 05-19-2008, 12:19 PM   #2
Sounds like a wheel bearing/tie rod/control arms issue?
Old 05-19-2008, 12:21 PM   #3
vadim321go
vadim321go's Avatar
vibrations from the front could be a million different things. i suggest taking the car to a mechanic.
Proud owner of a 95 325i
Old 05-19-2008, 12:55 PM   #4
Dado 540
Dado 540's Avatar
i would have to agree wiht vladim321go. could be the engine mounts, could be the tie rods, control arms, tires, wharped rims, even a wharped crank pulley... so two options left for you...1. take it to the mechaninc and have them check it out, 2. drive it the way it is untill the problem becomes so evident that it could be pin pointed.
Old 05-19-2008, 09:02 PM   #5
NOTORIOUS VR
NOTORIOUS VR's Avatar
^^^ I would avoid option #2 at all costs... Such a heavy vibration can be of no good... and might do more harm then good at this point.
Take it to one of Max Forums sponsors if you don't already have a mechanic that you can trust. I've sent a few people to Bimmersport and everyone has had only good things to report back to me.
Old 05-19-2008, 11:16 PM   #6
probably ball joints.
any half decent mechanic can tell you the problem in less than 20 mins.
Old 05-20-2008, 09:18 AM   #7
chromius
chromius's Avatar
It sounds like it's shaking while under load, so if that's the case, I would lean towards a driveshaft/center support bearing issue, or an axle shaft. Most other things that would cause a vibration would not change based on throttle application, unless it's an engine issue like a missfire, but it doesn't sound like it.
Old 05-20-2008, 02:49 PM   #8
hadesm5
hadesm5's Avatar
dude... its your muffler bearing
hadesm5 is offline   Reply With Quote
Old 05-20-2008, 02:51 PM   #9
Simby
Send a message via MSN to Simby
I say the water pump is broken. That's what my car felt like right before it died.
Simby is offline   Reply With Quote
Old 05-20-2008, 02:52 PM   #10
mirek
mirek's Avatar
My money is on shredded flexdisc or engine mounts
Old 05-20-2008, 03:10 PM   #11
EmmEff
It's probably the piston return spring.
EmmEff is offline   Reply With Quote
Old 05-20-2008, 03:39 PM   #12
Toxic0n
engine mounts?
Ground Control Street/School coilovers, 19" HRE 441R wheels, ACS exhaust
2DIN touchscreen carputer, Bimmian CF E-brake handle, Titanium CF Trim, Illuminated ZHP knob, BMW Performance SSK
OEM Clears, LED license plate lights, angel eyes, matte grills, CF Emblems etc
Toxic0n is offline   Reply With Quote
Old 05-20-2008, 04:04 PM   #13
Wingking
Wingking's Avatar
are you still running the winter air in the tires?
change to summer air.
Wingking is offline   Reply With Quote
Old 05-20-2008, 04:17 PM   #14
Bartacus
I had something similar, and mine turned out to be a bad ignition coil on cylinder #3, due to sucking water up through my CAI. Good times, good times.
Bart
Bartacus is offline   Reply With Quote
Old 05-20-2008, 04:39 PM   #15
vadim321go
vadim321go's Avatar
like i said before it could be ANYTHING, you can see by the responses that your best bet is a mechanic
