Old 05-19-2008, 12:33 PM   #16
Whip_lash
Whip_lash's Avatar
Originally Posted by windsor318is View Post
dude, do you have that thing lowered? no rubbing in the back??? i need some beefy tires in the back need to see how wide i can go.
Im running 16x9's all around with a 60/40mm drop. No rubbing issues excpt for the rear left when i make a hard right turn. I dont know if bump stops should be able to prevent this or I might have to roll my fender a bit.
Whip_lash is offline   Reply With Quote
Old 05-19-2008, 11:04 PM   #17
andicanada
andicanada's Avatar
what whell setup is posible with the e36ti part's ? can you run 9'wide rim's like that ?
oh and by the way i toke a look for clearance with the rim's and tires i have on right now you dont have to do any fender work only some bumb stops in stock hight
Old 05-20-2008, 03:40 PM   #18
tominizer
225 35 18 all the way around................... I'd say........ euro stretched look on 9" wide
Tom
Current : 2013 Mini Countryman JCW, 2007 Z4M Roadster
Past: '88 E30 M3, '69 BMW 2002 Ti, 2000 328i, Audi A6 TT, BMW X5 3.0i , Audi A4, Mini Cooper Clubman S 1.8T
Old 05-25-2008, 11:19 AM   #19
NOTORIOUS VR
NOTORIOUS VR's Avatar
Any update on how to do your custom 5 bolt swap?
Old 05-25-2008, 01:53 PM   #20
andicanada
andicanada's Avatar
ok i'm using a e30 special made e30 hub with 5x120
for the front i go the same way with a custom hub
Old 05-25-2008, 02:00 PM   #21
ZiMMie
how thick its the custom hub?
#E36-S54 #CSLWannabe
Old 05-25-2008, 02:21 PM   #22
andicanada
andicanada's Avatar
i guess it was 12mm or so i have to go to my shop and look for the drawing's.
but it works better then i thought it would be
i only have like 5mm to the trail arm and 255 tires can be driven without any rolling on the fenders
and with the front i changed my mind and may go with z4 breaks by the way does anyone has drawings for the z4 front break disc ?
Old 05-26-2008, 12:29 AM   #23
Pictures of said hub. What brakes did you use for the rear? Still has a working handbrake? Pics pics pics!!!1
For the drawings of brake discs, I vaguely remember seeing some charts and drawings on Brembos website. Go browse there, may have something. http://www.brembo.com/ENG
Old 05-26-2008, 01:48 AM   #24
andicanada
andicanada's Avatar
for right now e30 stock break in the back but i have a z4 one laying araund what would fit nicly with some work
and the e-break is still working
Old 05-26-2008, 10:39 PM   #25
windsor318is
Nitrous Junkie!
windsor318is's Avatar
thats what i thought, i already made a set myself over a year ago, im going to be running 19" hartge rims, wanted to see how wide i could go on the back, so you said spacers are 12mm could you double check please?whats the offset on that rim? did you just leave the one bolt missing? 4x100 to 120x5 is impossible they overlap. im planning on threading a nut into the rim.
Old 05-26-2008, 11:20 PM   #26
andicanada
andicanada's Avatar
what????????????
hey sorry i do not use spacers, the hub is 10mm thick like stock all bolts fitt great, i have a second set laying in my shop for a E30 5 LUG conversion i repeat 5 lug and not 4 1/2 lug
AND PLEASE NOTE!! NO SPACERS OR NUT'S ARE USED!!!!!!!!!!!!!!!!!!!!!!!!
I WENT FOR THE BEST WAY I THINK, ALSO DID SIMULATIONS ON THE COMPUTER FOR THE HUB STRESS TESTING AND SO ON
you can go 275 wide with moderate fender work on a 9 inch rim
Old 05-27-2008, 12:43 AM   #27
So wheres the pics? I think we'd all like to see pics of the hub by itself, hub installed in the trailing arm, and whole assembly with the brakes installed...
Old 05-27-2008, 10:22 PM   #28
andicanada
andicanada's Avatar
i dont post the pic. off the hubs. you see the rims are on the car and break works fine and e-break.
when the time comes and the test's are good, i might start selling theys kit's front and rear for the original break system or upgradet breaks till then i want to keep things low
for more questions pm me
Old 05-27-2008, 10:39 PM   #29
windsor318is
Nitrous Junkie!
alright im lost........send me a pm. i need the 275 on the back....bad
Old 05-27-2008, 10:57 PM   #30
andicanada
andicanada's Avatar
why lost ? never seen a 5 lug hub what fits a e30 !?
