Old 04-23-2011, 08:37 PM   #16
Dado 540
Dado 540's Avatar
Thrust arm bushings
E39 540i Sport
Old 06-17-2011, 05:22 PM   #17
SFX Group
SFX Group's Avatar
Normally in this order (was more so with the v12 a was heavier), assume =g this is coming from the steering area.
Warn tires (read below), unbalanced wheels, un tracked wheels (will also created warn tires = catch 22).
Warn front control arm bushes (this was my problem on my car).
new tires will clear it up for about 1000 miles then it will com back, this confirms a balance / control arm bush issue (bush located right at the front of the car for balancing the suspension both sides), I put poky versions on mine as BMW parts would wear out in about 4 weeks (made of rubber).
Many Thanks
Ashley
© Copyright 2015 - www.ashleygriffin.ca ::: Click to see my current second hand parts :::
::: My Videos :::
::: LED side indicators ::: Navigation Mk2 to Mk4 upgrade ::: Glovebox position damper ::: 740Li 2013 tour ::: Voice Control teaser trailer :::
>>> Click picture to see my car used on TV as the James Bond car <<<<
SFX Group is offline   Reply With Quote
