04-28-2008, 12:34 PM
#1
Car: Mini Countryman JCW
Anyone here running MEGASQUIRT for engine management ??
Just curious if anyone here is running that system ? Thoughts/feedback would be appreciated.
It's more of an interest thing right now for me but in the not too distant future, I will be going to stand alone. Just not sure which one .............. and more importantly, is the issue of local tuning support. I know with the MEGASQUIRT setup, a basemap to at least get up and running is available, but it will ultimately require dyno time and tuning.
Cheers,
Tom
Current : 2013 Mini Countryman JCW, 2007 Z4M Roadster
Past: '88 E30 M3, '69 BMW 2002 Ti, 2000 328i, Audi A6 TT, BMW X5 3.0i , Audi A4, Mini Cooper Clubman S 1.8T
04-28-2008, 03:53 PM
#2
cra.iX.y
Car: '84 VW Rabbit TD
w0rd
been running it for maybe 6 months now. only engine mod is 33lb injectors. (i know they're huge, but its waiting for the supercharger)
04-28-2008, 03:58 PM
#3
Fury, who did the MS build for you and the programming maps???
Tom
04-28-2008, 06:06 PM
#4
Car: E30 M3, E46 330i, X5
Running MS2 V3.0 put about 4K on my 2.7i with it.
Built it myself, ordered the kit from diyautotune.com. The map I just used other peoples and tweaked them. There is a bit of a learning curve but in terms of tuning it's just a VE table like most other stand alones.
04-28-2008, 06:18 PM
#5
BMW again.
Car: 1994 325is
check out the FI section on BF.C lots of faithful guys running all different versions of MS.
04-28-2008, 07:53 PM
#6
cra.iX.y
rs4pro3 on e30tech. i did all the maps myself. i have the pwm idle hooked up as well, with the glens' garage board.
i've done 2 megasquirt setups now, on my car and on a buddys.
if i was to do it again, id definitely build the board myself. theres an adapter board available for the 55pin motronic, its basically a solder-in, then connect with a relay cable. i have the jimstim too, which i used to fix a few problems on my buddys board, so i can test the boards properly.
if anyone wants, id be happy to build a megasquirt and load a map in that'll definitely get the car started/running well.
04-29-2008, 08:27 AM
#7
I was talking to rs4pro3 actually on www.s14.net as he has built a board for the E30 M3, but just doesn't have a car to test it on. His build goes inside the E30 M3 OEM ECU casing. It's kind of slick, but he's not local, nor has he found a car to test it on yet. And I hate being the mule being so far away. IF I was to walk down the road, I was looking for someone with MS experience................. like lots of it.
Tom
04-29-2008, 07:31 PM
#8
cra.iX.y
mine is inside the ECU casing as well. i fit everything inside, including the glens' garage PWM idle board.
i dont see how the m3 would be a whole lot different, its still cap and rotor, you probably would have to run alpha-n for idle at least, because of the ITB's, but if you ran a vacuum runner between all of them, you might be able to use MAP.
naturally aspirated, there's no reason not to use alpha-n, because no extra air is getting forced in.
good thing about a plug and play system is that you can always revert easily. is the m3 TPS variable? or a switch? if it was variable, then that eliminates another change.
it may be a straight-up plug and play. you never know. is the m3 dme different than the normal e30's? pin-wise?
04-29-2008, 08:34 PM
#9
Car: E36 turbo
To the OP, if your car is an E30 check out http://e30tech.com there's tons of info there about MS. Even if it's not an E30 you might want to check it out, it's at least a very BMW specific forum. There are people there running it with M50/52 swaps as well.
Another DIY ECU you might want to look into is VEMS. It's a little more complicated, but the hardware is much better. Either way do a lot of research before committing to anything. Another persons solutions isn't always the correct solution for you.
Thread Tools |
Display Modes |
