04-16-2008, 07:12 PM
#1
cra.iX.y
Car: '84 VW Rabbit TD
Look what came in the mail today....
Whole subframe rebuild kit!!
Now i can finally fix my wonky camber. I am thankful that i have parts cars i can pull the subframe out of, fix up, and get everything installed, and just swap 'em.
04-16-2008, 07:34 PM
#2
Herr Meister
Car: 1984 e30 318i / 2005 e46 325i
Got the same kit last month :-)
1984 318i w/M10 - restomod in progress :-)
1984 325e - in car heaven now :-(
1991 325i - project / parts car
2005 325i executive edition - daily driver :-)
http://www.cardomain.com/ride/2831989
04-16-2008, 09:43 PM
#3
Car: Z3, M3 (e36)
Who is going to weld that for you? I have the same thing for the Zee...
T.
T.
04-16-2008, 11:49 PM
#4
cra.iX.y
i think im going to do it myself. if its prepped well, should be a cinch to weld it. i have some experience welding stuff, so it should turn out alright. if not, i have a friend who is amazing - he's the fall-back plan.
04-17-2008, 09:43 AM
#5
Northwood.
Car: 11 Grand Cherokee
how much $$$
Current - 2011 Jeep Grand Cherokee Laredo
2010 Jeep Patriot North All-season
2009 Jeep Wrangler Unlimited Sahara
2002 Dodge Durango SXT
1985 BMW 325e
1998 Pontiac Grand Prix GTP
1995 Nissan Altima SE
1994 Mazda MX-6 RS
1984 Buick Riviera
04-17-2008, 09:51 AM
#6
The Afro-stig
Car: Is Fast. ;)
Nice...are those the IE trailing arm bushings? Get ready for them not fitting
04-17-2008, 10:44 AM
#7
Herr Meister
I paid $120 for the set and they do fit :-)
04-17-2008, 10:57 AM
#8
The Afro-stig
Car: Is Fast. ;)
Mine were a total nightmare....on the stock pivot points they WILL not fit unless you sorta pull the tabs more open and use madd lube...dissapointing. If i were to do it again I would of gone with the AKG trailing arm bushings but i got the IE's for such a great price so whateva, i just made shit work
BTW I love what you've done with my old trailing arms!
04-17-2008, 12:27 PM
#9
Herr Meister
Mine were not that bad, but it required some work.
The trailing arms needed some cleaning up because of the color change, but I think they look good.
Thanks for your help with them !
04-17-2008, 02:22 PM
#10
cra.iX.y
i got all the above for 280+shipping, its a group buy on e30tech.
i noticed on the trailing arm bushings that the lip on one side is thicker than the other - if they dont fit, ill just cut them down with a hacksaw or something.
04-17-2008, 02:47 PM
#11
Over 9 F**KING THOUSAND!!
Car: '91 325iS | '96 332i
Make sure you position them properly, tack weld two opposite corners, and then pull the tabs off and enlarge the hole. If you don't position them properly before welding them in for good your camber will be wonky.
04-17-2008, 06:49 PM
#12
cra.iX.y
so tack them, mark the new hole, then grind off the tacks, take them off and enlarge the hole?
by not positioned properly do you mean angled not quite vertical?
