Old 04-16-2008, 03:25 PM   #1
S.A.330iM
S.A.330iM's Avatar
harmon kardon?
Need info. I searched and found reference to speaker upgrades, but what i like to know is what is the basic minimal speaker upgrade can i do with out having to change out all the speakers?ie mid,lows highs....
Althoug the bass is decent for me, what can i upgrade them with without putting in a dedicated sub box, and still get a better bass?
I don't know much at all about the HK stereo or it's components. Thanks for any help. Manual says nothing
S.A.330iM is offline   Reply With Quote
Old 04-17-2008, 08:45 AM   #2
S.A.330iM
S.A.330iM's Avatar
I should clarify, whats the first set of speaker i can replace that will make the most impact in sound qaulity(fronts,rears,rear deck)? I think 6X9 are the subs correct? If so how to keep stock and improve the bass? Thanks
Old 05-08-2008, 08:30 PM   #3
04330CI
I've been wondering the same thing, I have the HK system and the bass is alright, but could use some improvements..... Since the battery is so convieniently located, amp mounting/wiring/fuse/ground is pretty easy - only problem is getting a signal to the amp......Im pretty sure anywhere you splice off of would have an amplified signal which would cause the amp/sub to distort.....
Any thoughts on where to get the input signal from?
04330CI is offline   Reply With Quote
Old 05-08-2008, 10:17 PM   #4
skru_fase
Lurker
skru_fase's Avatar
my setup takes the signal from the rear subs into my amp... pretty straight fwd i think (but then again, i wasn't the one that installed it)
jl stealthboxes might be a viable solution for you...
skru_fase is offline   Reply With Quote
Old 05-09-2008, 12:19 AM   #5
ZHP_Bimmer05
Photographer/DJ/Engineer
Send a message via MSN to ZHP_Bimmer05
Im gettin a pair of 12" crossfires and gettin them installed by 20hzAudio. They are awsome they did my double din, and did Gary Collins(Orange M3 aka OafGuy) system too. I like the hk system, has go sound, just want a bit of punch on the bass.
2004 Mazda RX8 GT: 6spd VR
Work VS-XX 19x8.5 +38 19x10 +36 | Yokohama Sdrive 235/35/19||265/30/19 |TurboXS V.2 Catback Exhaust System | TEIN Flex Coilovers w/ EDFC controller | EBC 3GD Slotted Rotors w/ RedStuff Pads | OEM Side Flares, Rear Deflectors | AutoEXE Carbon Fiber Shift Knob
ZHP_Bimmer05 is offline   Reply With Quote
Old 05-09-2008, 10:47 AM   #6
Romaz
Is now married :D
Romaz's Avatar
Gary's car is a 330ci not an M3
Romaz is offline   Reply With Quote
Old 05-09-2008, 03:25 PM   #7
ZHP_Bimmer05
O i know, it was on tuner transformation, but come one, it almost is
Old 05-09-2008, 09:12 PM   #8
S.A.330iM
S.A.330iM's Avatar
does the HK have 6X9 as subwofers? if so antway to improve them(bass wise) ei better amp, different 6X9? I like the idea of full trunk space
B-bella
M-machana
w-WILIO
