Old 04-14-2008, 12:57 PM   #1
540i6
540i6's Avatar
Oxygen sensors
I installed high flow cats on my 98 bmw 540i and i keep getting an engine code from the two oxygen sensors after the cats. I was just wondering if there's any oxygen sensor simulators out there for this make and model that will bypass this code? If so where can i get them? Help is highly appreciated!
540i6 is offline   Reply With Quote
Old 04-14-2008, 03:00 PM   #2
Maxim
Is there a reason you want to simulate them? It should be cheaper to replace them... what is the exact code you're getting - is it insufficient catalyst efficiency code or broken sensor code?
edit:
If it is efficiency you can start cheap by installing spark plug defoulers as spacers.
http://forum.e46fanatics.com/showthr...ht=o2+defouler
Maxim is offline   Reply With Quote
Old 04-16-2008, 04:15 PM   #3
540i6
540i6's Avatar
It's an Insufficient catalyst effieciency code.
Old 04-17-2008, 09:46 AM   #4
Maxim
Yeah, I'd try spark plug defoulers. In US EPA pretty much cracked down on the o2 sim makers (i.e Casper), so they are difficult to find.
Old 04-17-2008, 10:01 AM   #5
540i6
540i6's Avatar
I'll try it out and hopefully it works. Thanks for the info, you've been very helpful!
