Old 04-05-2008, 10:36 PM   #1
Spawn44
wipe on wipe off vs let dry and wipe(klasse SG)
Well gang just about time to use the Klasse twins for my first time. I was just wondering what method i should use for the SG. wipe off immediatley or do i let it sit (for how long?) then remove.
I have never used Klasse and have only used otc wax from canadaian tire in the past. So which would be the best way, because i dont want to lose any of its effects by doing the wipe off immediatley if it takes away from the final look.
thanks in advance
Spawn44 is offline   Reply With Quote
Old 04-06-2008, 11:20 AM   #2
HoldenC
Pro Mobile Detailing
thanks in advance
Actually, I already answered this question in a previous thread. There is one thing to note, though. You must wait 24 hours prior to application of a layered coat of Klasse SG.
http://www.maxbimmer.com/forums/show...92&postcount=5
Originally Posted by HoldenC
Klasse SG is only difficult to apply, as I stated, when applied too liberally. Less is more when it comes to detailing. No need to wait any time, though. There is no real "cure" time for Klasse.
I don't really recommend using a QD without washing. Ideally, you will use a QD to perform upkeep on the coat of SG.
A great formula for a QD is to mix distilled/filtered water with SG at a ratio of six parts water, one part Klasse SG (6:1). Alternately, you may use Meguiars UQD, Poorboy's Spray & Wipe, or Wolfgang Instant Detail. Any of these will be perfectly fine.
It is recommended if you perform a detail only twice a year to use both Klasse AIO & SG at each time. I would also recommend that you use a claybar each time. The clay will remove some wax and anywhere from 80-100% of embedded contaminates. AIO will remove the remainder of the wax making the finish LSP ready.
HoldenC is offline   Reply With Quote
