Welcome to!
Old 03-23-2008, 04:40 PM   #1
all you need is one mike
koncise's Avatar
Send a message via MSN to koncise
Exclamation Window Problem
Rear drivers side window will only go down, not up. Thats from both switches (in the door, and next to the shifter).. so I'm thinking it's probably not a switch. But since it goes down like normal, doesn't seem to be the motor either. But I really dont know.
Anyone have this problem before? Or just know what the problem is?
P.S. Is there a way to manually crank the window up (it's stuck almost half way down)... I took the door panel off but couldnt see any way to get the window up. And it wont let me just pull it up.
koncise is offline   Reply With Quote
Old 03-23-2008, 05:11 PM   #2
I had a similar problem with my 97 E36 Coupe. Here are a few things I tried.
1. roll window all the way down and hold the button for about 5-10 seconds. Someone told me that resets the window motor, then push up and it should go up
2. manually (with the key) unlocked and locked and unlocked (held the key in the unlock position for about 5-10 seconds) the door from the outside. after this it the windows whent right up
Not sure what did it, but those are the two things I tried in my coupe.
Current Rides: 964 C2
Past Rides: 94 318is, 97 M3, 01 C2 Cab, 02 330ci, 06 323i, 05 330cic M Sport, 02 M3
Spoose is offline   Reply With Quote
Old 03-23-2008, 09:01 PM   #3
Run 12V straight to the window motor, it will go up/down by reversing the + and -
