Old 03-19-2008, 06:41 PM   #1
Spoose
To Offset or not to Offset, that is the question...
Guys, I need some input/opinions here. On my E36 M3 I want a new set of wheels, should I get a set of offsets or not. My current OEM wheels are offset, and I like it. I want to move to a bigger size wheel, maybe a 18 or 19. What do you guys think, is an offset set better or no real difference.
Current Rides: 964 C2
Past Rides: 94 318is, 97 M3, 01 C2 Cab, 02 330ci, 06 323i, 05 330cic M Sport, 02 M3
Spoose is offline   Reply With Quote
Old 03-19-2008, 07:01 PM   #2
Quickid
What do you mean by "a set of offsets"? Sorry but I'm not familiar with the term.
Are you referring to spacers by any chance?
Quickid is offline   Reply With Quote
Old 03-19-2008, 07:03 PM   #3
Spoose
no I mean wider rims for the rear then the front. I guess you can call it staggered.
for example, on my M3 the fronts are 7.5 and the rears are 8.5 wide. I am thinking of going 8 in the front and 9.5 in the rear or just going 8 all around.
just wondering if there is any drive/ride enhancements by doing it or is it just for looks. expecially in a larger rim such as a 18 or 19.
Old 03-20-2008, 09:57 AM   #4
cisco911
Think about it logically. The power goes to the back wheels, so by adding more rubber in the back, you get more grip, which equals better accelleration. The only downside to it is that you can't rotate your tires and you will, depending on your driving habits, be replacing rear tires more often than fronts.
Old 03-24-2008, 10:04 PM   #5
PROJECT_E36
+1 exactly what i was going to say
PROJECT_E36 is offline   Reply With Quote
Old 03-24-2008, 10:10 PM   #6
LOL@thread title
Old 03-25-2008, 10:27 AM   #7
sthomas
BMWCC 4928, BMWCCA 349578
Staggered tires also affect handling - specifically under/over steer. By putting more rubber at the back, you reduce over-steer / induce under-steer at the limit. It also affects slip angle, so even the feel of the car, before actually skidding, will be affected.
The factory likes understeer - and one way to dail it out is to change from staggered to equal width.
2002 540i M Technic
1993 325is RIP
sthomas is offline   Reply With Quote
