Old 03-17-2008, 03:55 PM   #1
summit425
Alpine White
FS: Samsung SCX-4200 Multifunction Laser Printer
Features:
Print Method: Laser Beam Printing
Speed: Up to 18 ppm in A4 (19 ppm in Letter)
Resolution: 600 x 600 dpi
First Print Out Time: 11 seconds (from Standby mode)
Copy Speed: Up to 18 ppm in A4 (19 ppm in Letter)
Resolution (Optical): 600 x 600 dpi Text, Text/Photo mode : 600 x 300 dpi Photo mode : 600 x 600 dpi
Resolution (Enhanced): 600 x 600 dpi
First Copy Out Time: 11 seconds (from Stand by mode)
Zoom Rate: 50~200%
Multi Copy: 1~99 pages, Duplex Copy
Scan
Compatibility: Twain standard, WIA standard
Method: Color CIS
Resolution(Optical): 600 x 2400 dpi
Resolution(Enhanced): Max. 4,800 x 4,800 dpi
Effective Scan Length: 297 mm ( 11.7")
Effective Scan Width: 208 mm (8.2")
Color Bit depth: Internal : 24 bit, External : 24 bit
B/W Bit depth: 1 bit for Text mode, 8 bit for Gray mode
Gray Scale 256 Levels
Paper Handling: Input Capacity and Types 250-sheet Cassette Tray (75 g/§³, 20 lbs), 1-sheet Manual Tray
Output Capacity and Types: 50-sheet Face Down(75 g/§³, 20 lbs), 1-sheet Face Up
Media Size (for Print): Tray: Legal, A4, Letter, Folio, Executive, B5, A5, A6 Manual Tray: Legal,A4,Letter, Folio, Executive, B5, A5, A6, Envelope #10, DL, C5, C6, B5 - 76 x 127 mm (3" x 5") ~ 216 x 356 mm ( 8.5" x 14")
Net Dimension (W x D x H): 409 x 362 x 232 mm (16.1" x 14.3" x 9.1")
Weight with Consumables: 9.3Kg
LCD: 2 line x 16 characters
System Memory: 8 MB
Interface: USB 2.0 (High Speed)
OS: Windows 98/Me/2000/XP - Various Linux OS including Red Hat 7.1 and above, Mandrake 8.0 and above, SuSE 7.1 and above, Caldera OpenLinux 3.1 and above, Turbo Linux 7.0 and above, Slackware 8.1 and above. - Mac. 10.3, 10.4.
Warm-up Time: Less than 42 seconds (from Sleep mode)
Noise Level: Warm up : Less than 45 dBA Stand by : Less than 38 dBA Printing : Less than 53 dBA
Power Requirement: 110 ~ 127 VAC, 50/60 Hz, 4.0A 220 ~ 240 VAC, 50/60 Hz, 2.5A
Power Consumption: Sleep mode : 10 W Standby mode: 70 W Average : 350 W
Duty Cycle, monthly: Up to 10,000 pages
Consumables: Single Cartridge
Yield: 3,000 pages at ISO 19752 5% Coverage (Ships with 1,000 pages Starter Toner Cartridge)
Code: SCX-D4200A
Options: Network Ethernet 10/100 Base TX (External) : ML-00ND
http://www.letsgodigital.org/en/news...tory_5924.html
Retail : $120 + tax
Only Asking $80 obo.
in mint condition everything works fine!!!
summit425 is offline   Reply With Quote
Old 03-18-2008, 02:20 PM   #2
summit425
Alpine White
bump!!
$70 obo
Old 03-20-2008, 01:57 AM   #3
summit425
Alpine White
sold!!! Thanks carboy88
